18x8 Alcoas in the Rear - Any Extra Work?
Old 05-06-2011, 01:46 PM
LS4:20's Avatar
Default 18x8 Alcoas in the Rear - Any Extra Work?
They've been sitting in my garage waiting for a set of tires for about 4 months now.. Anyways, grabbing a set in a couple weeks and was curious if there is any extra work involved or will the 18x8's, WITH 275's, just bolt on no problems?
Old 05-06-2011, 01:48 PM
LS1>girlfriend's Avatar
You may have to roll the fenders if you're lowered or carry a few people in the back seat.
Old 05-06-2011, 02:10 PM
2005gxp's Avatar
you WILL rub, need smaller tire, roll fenders.
Old 05-06-2011, 02:32 PM
GXP25's Avatar
Do 255s all around with the 8s in the rear.
My extra 8s are getting refinished. Then they'll be going out back.
Old 05-06-2011, 02:55 PM
LS4:20's Avatar
255's are okay to shove right on then? That works.. I'll just downgrade from the 275's.. Grip isn't much of a difference anyways.. Thanks guys..
Old 05-06-2011, 03:57 PM
Panther427's Avatar
ya 255/45/18 will fit good. Im running 245/45/18 all around even on the 18X7 with my snow tires.. Only had a little issue in heavy snow building up to rub between shock tower and tire once.
Old 05-06-2011, 07:58 PM
Mgpeagle's Avatar
I have 255's all around and they do not rub. I am not lowered though. Much less torque steer too.
-Mike
Old 05-07-2011, 08:33 AM
LS4:20's Avatar
FYI: I am NOT lowered, and if I do any lowering, it's going to be front end only to help with launch traction.. 275's fit the rear at stock ride height, correct? I know one member runs the 275 Hankook Ventus V12's at all four corners, and lowered..
I plan on stiffening the rear end at stock ride height as well to help the squatting off the line, so that should reduce chances of rubbing with passengeres as well, though it's gonna be one rough ride... Lol..
Quick Reply: 18x8 Alcoas in the Rear - Any Extra Work?
