power, ground for a pillar gauges
I am installing an a pillar gauge pod for my boost controller, trans temp, and wideband gauge/sensor. I was wondering if anybody had recommendations for a solid grounding point - the wideband was very specific in using a reliable ground or it might now show accurate results...it even mentioned using an engine ground? The closest engine ground is towards the front drivers aide of the engine bay, and I had thought you also wanted a relatively short ground wire length if possible. Also, I was wondering what the best 12vjust supply would be? If there is a good write up somewhere and I missed it, I apologize.
