Deleting the factory bose stuff?
I have a 94 Z28, it has just three speakers(Bose). Do the door speakers have amps also? I was thinking of deleting all the factory speakers and just running something in the sail panels. Will it sound alright? If I go this route what should I put in the sail panel, 6x8, 6x9?
Head unit is a Alpine CDE-102. Would I just pull all the factory speaker wiring and run speaker wire to the sail panels? How would they mount in the sail panels, are there already holes for screws?
What's the purpose for deleting the speakers in the doors and just running some in the sail panels? Are you trig to lighten the car? I honestly don't think it would sound right, I'm also not sure a 6x9 won't fit in the sail panel either.
Thanks everyone, I'll just run some door speakers then. I was planning on new wires anyway, its such a mess behind the head unit. There is this black box I guess to make the head unit happy with the Bose stuff, there is just wiring everywhere.
What would be a good pair of door speakers, knowing this is all I will be running?
I tried those awhile back just temporarily and they sucked, within no time they were blown which sounded worse than stock.
Ungrounded Moderator
The black box is probably an adapter for the Bose system such as a PAC OEM-1. It is basically an adjustable line out converter that steps down the speaker-level output of the head unit to the low-level input needed by the Bose amplifiers. I don't think the 94 Camaro had DRLs so it wouldn't be a DRL module.
Should I go with Alpine type R's or something? Speaker recommendation, just to run two door speakers.
Pulled the rear Bose yesterday, if anyone is looking for one. Damn that was a clunky funky shaped box.
Are the Pioneers really that cheap that with just 50w I'll kill them?
