Advanced Engineering Tech - Electrical question
View Full Version : Electrical question
dpmalibu
05-07-2011, 01:22 PM
I am parting out an 98 T/A. This is my first experience with LS1 cars so I really have no clue. A friend of mine had asked me if I pulled the trans out of the car would the motor still run normally. He thought it may not run the way it is supposed to or that it would go into "limp mode" since some of the harness would not be hooked up causing a break in the signal to the computer. Does anybody know the answer to this question? will the car still run okay If I pull the trans out before the motor? Thanks in advance for any feedback.....
Bluestreak
05-07-2011, 08:57 PM
There are several switches in the trans that the PCM looks at for information. It will set codes, but you should be able to start the engine and it should idle. I've done this in extreme cases to isolate noises and vibrations on RWD customer cars.
dpmalibu
05-07-2011, 11:00 PM
Ok Thanks.
