baffled tank, Do I really need one?
Old 05-07-2011, 03:27 PM
SCOTTYSALESMAN's Avatar
Default baffled tank, Do I really need one?
Working on a 63 Corvette LQ4 conversion. I have all the components for the external fuel pump, regulator, etc. I don't plan on racing and usually keep the gas level up. Do I really need a baffled tank. They are pretty pricey. Thanks,
Scott!
Old 05-07-2011, 05:34 PM
garys 68's Avatar
Not really. The C2/C3 corvette tanks are deep and even angled toward the pickup. I've been well under 1/4 tank and not had problems. At 1/8 tank, it will stumble on cloverleafs.
I also just did a 72 Olds 442. That tank is low and wide. I doubt I could get away without one there, so I put in a sumped tank.
Old 05-24-2011, 12:40 PM
bump any other opinions
Old 05-24-2011, 12:48 PM
rockytopper's Avatar
No you don't need one for the street. As Gary stated you may experience fuel starvation at the bottom end of the tank if you are playing hard. For normal driving you want even notice it.
Old 05-24-2011, 01:06 PM
thx guys!!!
Old 05-25-2011, 10:56 AM
trav-tech's Avatar
One other option is to add a remote style serge tank. You run a Carb style pump (low Psi high volume) from the main tank to the serge tank and your high Psi pump draws from it feeding your fuel rails. I make them around a quart in size maybe a little larger if you have the room. Can be mounted in the trunk or under the car. The return line from your fuel rail feeds back into this serge tank and you also run a spill over line back from the top of the serge tank to the main fuel tank. Works very very well. We run them in all our off road vehicles and most of our street builds.
