LQ4 to TH350 Pics of problem included
Old 05-08-2011, 12:44 PM
talon2008's Avatar
Default LQ4 to TH350 Pics of problem included
Heres the low down, I have a th350 with a 4k stall I purchased used. I also purchased the gm spacer and bolts to go on my 6.0 flex plate, but the problem is the guy that I purchased the used th350 and stall from cut the outside bolts off the dual pattern stall converter!!!!! Now I messaged a few people on here and their response was to get a new stall which will NOT be happening!!
The question I have is : Can I use another STOCK form flexplate on my lq4 to allow me to bolt up a small bolt pattern torque converter.
Old 05-08-2011, 01:27 PM
2xLS3's Avatar
Take the flex plate to amachine shop and have them drill it for the other pattern
Had to do it on a powerglide swap, that didn't have the correct bolt patern
Old 05-08-2011, 02:02 PM
71ANTICARB's Avatar
I would get a new converter or atleast send that one back to the manufacturer to have the tabs replaced. I would be worried bout it be out of balance.
Old 05-08-2011, 02:42 PM
talon2008's Avatar
https://ls1tech.com/forums/automatic...0r4-4l60e.html
I have been looking at this thread. I am wondering if this means I can use the spacer I have + the bolts that I have and use a 4.8,5.3, or ls1 flexplate. It say's it will fit the small torque converter pattern, but not 100% sure.
Old 05-08-2011, 03:41 PM
LS1MCSS's Avatar
The spacer makes the converter snout reach the end of the crank. It has nothing to do with your problem. Like was said above, have your flex plate re-drilled at a machine shop.
Old 05-08-2011, 05:12 PM
talon2008's Avatar
2. you do not need a special flexplate, the curved 4.8,5.3,LS1- just need the t/c bolt holes ovaled out a bit and the 5.3 flex plates have a set of holes that match the small gm t/c bolt pattern perfect
Copied that from the link previously... so your telling me a 4.8 5.3 or ls1 flexplate will NOT work with the small bolt pattern torque converter??? I am not having a machine shop drill holes in my 6.0 flexplate for 50-60$ when I can get a used 4.8 flexplate for 20$, just trying to see if it will even work.
Old 05-08-2011, 07:26 PM
deuce4935's Avatar
Get a 5.3, 4.8 or 5.7 flex plate and the spacer from GM or Hughes and you will be able to use the small bolt pattern holes on the converter.
Old 05-08-2011, 07:35 PM
talon2008's Avatar
^ thank you. was just looking for reassurance and double checking myself.
thanks again!!
Quick Reply: LQ4 to TH350 Pics of problem included
