User Support & Resources - I accidentally hid my "Marketplace Search" box, how do I get it back?
T AM
05-08-2011, 03:39 PM
I was searching the parts classifieds a few days ago and accidentally clicked the "hide marketplace search" button. I tried logging off and logging back on and clearing the cookies. How do I get the search box back? Thanks.
01ssreda4
05-08-2011, 04:58 PM
There should be an icon for it on the left of the threads.....
JeremyT
05-08-2011, 09:20 PM
As 01ssreda4 stated, there should be a click-able image that will expand the search box:
http://www.ls1tech.com/forums/attachment.php?attachmentid=294722&stc=1&d=1304907531
The above click-able image is hosted external from LS1Tech, so if you're blocking remote images or have some other filter to block external content, it may not display.
Also, the option is cookie-based via one cookie. Several LS1Tech cookies are used for site preferences, so you may not have deleted the right cookie (or all LS1Tech cookies) to revert.
T AM
05-09-2011, 01:19 PM
Thanks JeremyT! I still don't see that clickable image you show in the screen shot, but I'll try it on a different computer and see if I can get it work.
JeremyT
05-09-2011, 05:51 PM
Look for the "marketplace_widget_collapse" cookie under LS1Tech. This cookie is set if you use the Hide Search in the Classifieds. If that cookie is not there, default will have the Search displayed.
If you don't see the image, make sure you're not filtering content from http://static.ibsrv.net
Can you see the following embedded image? If you don't see the image below this sentence, then you must be filtering content:
http://static.ibsrv.net/mp/tout.png
