engine controler
Old 05-08-2011, 08:41 PM
bj.949's Avatar
Default engine controler
How is it that the gmpp engine controller works without the vss signal or am I not reading the fine print.I asked at the dealership and they don't know if it needs it or not. I am talking about with a manual trans. If vss is not needed how do they get around problems associated with using a stock system with out vss? Anyone using the gmpp controller with a manual trans?
Old 05-09-2011, 05:24 AM
Jones'n's Avatar
I run stock ECUs with no VSS all the time, it isn't a problem to get around.
Old 05-09-2011, 05:45 AM
rsz288's Avatar
The GMPP tunes are compiled with options set to not let lack of VSS signal get in the way. i.e. if VSS = 0 then for example engine rpm high with closed throttle on a downhill may set a DTC. And things like decel fuel cutoff.
GMPP controllers only run manual trans's.
