What length tips for TSP Rumbler?
I just ordered a TSP Rumbler catback without the tips because I wasn't a big fan of the ones available on the site. My question is: What length tips should I order that would put the tips just past the bumper on a Camaro?
I realize I can cut the tailpipes if needed but if anyone knew a set length that would work well please let me know. Thanks.
i looked and found nothing i liked either. your prolly going to have to trim them up a few inches and buy what you like. i found no other possibilities unless you want the RICER look. maybe theres more out there now then when i bought my rumbler... but i doubt it.
I'm thinking of getting these:
http://www.summitracing.com/parts/IMM-577565/
I kinda want to go 4 inch but I'm worried it might look too big, almost like a truck pipe or something.
This was the 4 inch option:
http://www.summitracing.com/parts/IMM-577577/
I'm thinking it might look dumb from the side through since you can see a ways back on the pipe on a camaro and it's only an 8 inch tip.
ive seen guys run an 8 inch tip like that on other systems. it actually looks ok. problem is the rumbler has a weird bend on the pass side tail pipe to keep the pipe angle lookin right. if you cut that much off it might look weird cuz that bend will be gone then.
Thanks for yoru input. I went ahead and ordered a 12 inch one before seeing your post, so I will wish myself luck. I report back how it turns out.
