Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Pinging issue?
Old 05-09-2011, 12:11 AM
chitown21y's Avatar
Default Pinging issue?
So I just moved to Seattle from Chicago and my car now is pinging at wot with 92 octane fuel in 1st gear only I think. Tried different stations and all. Is not tuned and has a stock computer. Never heard of this so curious what you guys think it could be?
Thanks Dave...
Old 05-09-2011, 01:21 AM
itsslow98's Avatar
Why are you running TR6 plugs? Might not be the problem but I would go back to TR55s.
Old 05-09-2011, 01:24 AM
JJSimon904's Avatar
That probably is not the problem, but yeah you should be running TR55 not TR6.
Old 05-09-2011, 06:25 AM
Gary Wells's Avatar
Bad fuel / gas.
water / condensation in fuel / gas.
Try a can or two of "Heet" and / or a couple of gals of 100 octane.
Old 05-09-2011, 10:26 AM
STAGEUP's Avatar
Check your fuel pressure, and clean your maf with maf cleaner. And nothing wrong with running TR6 plugs. Just leave them.
Old 05-09-2011, 10:27 AM
wcryan's Avatar
100 octane will throw a code, but it'll go off after a half a tank of gas or so after you run through it
Old 05-09-2011, 02:52 PM
Gary Wells's Avatar
Unleaded shouldn't. I'm not saying race gas here. Unleaded 100 octane does not throw a code.
Old 05-09-2011, 03:23 PM
wcryan's Avatar
100 octane unleaded race gas did it for me. Twice. But who knows. haha
Old 05-09-2011, 03:44 PM
Gary Wells's Avatar
I ran 100-104 octane unleaded in my '09 CTS-V straight for about 4 months. Never threw a code.
Old 05-09-2011, 04:15 PM
wcryan's Avatar
Looks like I need to upgrade
Old 05-09-2011, 08:55 PM
Gary Wells's Avatar
Are you sure that was not leaded race gas? Leaded will set off a code, plug your cats, & screw with your NO2 sensor. However, the sensor itself will generally go about 1/2 to a full race season, and the cats will last longer than that before they plug.
Was that out of a can or directly out of a pump?
Old 05-09-2011, 08:59 PM
wcryan's Avatar
made 100% sure it was not leaded. The only leaded was 110Octane on pump and I bought a 50 gallon drum of 100 unleaded race gas. 100 is usually good to put in just about anything from your lawn mower to your car
Old 05-10-2011, 07:05 AM
Gary Wells's Avatar
I dunno. I knew that they can sell 100 octane unleaded out of a pump in Kali, didn't know that they can go 110 though. And actual race gas is always leaded, has to be sold out of a can in Kali. Were you able to get up to our Cad V show on 04-09-2011 at Cars & Coffee in Irvine. Had 23 cars there, all V's excepting for 1 XLR or whatever they are.
Old 05-10-2011, 03:32 PM
wcryan's Avatar
No I had work : /.
Old 05-10-2011, 08:21 PM
chitown21y's Avatar
Ok so 4 different types of gas and a clean maf later with no change. It does it at wot right when it comes into the power in 1st 2nd and 3rd great from what I can hear?
Old 05-10-2011, 08:50 PM
-T-
-T-'s Avatar
friends mustang was running crazy lean due to his injectors... can you check fuel rail pressure?
Old 05-10-2011, 09:05 PM
STAGEUP's Avatar
Pull the 10 amp ecm fuse for 5 min. Then re install it. Take for a 20 min drive without going wot. After u complete the 20 min drive, try going wot. What u are doing here is doing a reset of your fuel trims
Old 05-10-2011, 09:07 PM
STAGEUP's Avatar
Also, don't forget to check fuel pressure.
Old 05-10-2011, 10:55 PM
chitown21y's Avatar
How should I check it just at idle then hit the gas and watch what it goes up to? And what should it be?
Old 05-17-2011, 09:19 PM
-T-
-T-'s Avatar
Ok. Here is some arm chair quarterback troubleshooting, fuel psi should be ~60 if I'm correct. If you have 60 at idle, don't stop there, you could have a fuel flow issue causing you to lean out at upper rpm's where higher flow is required with the same pressure. Your pump could have flow issues and still be able to supply the 60 psi at idle because of the low fuel demand if that makes sense to you. Try revving in neutral while checking fuel pressure, might not be enough though and will have to induce a load.
You could disconnect your fuel lines, add some excess hose, drop it in a bucket and see what she flows per minute.
Quick Reply: Pinging issue?
