LS4 Performance - weird things that are tied together in our cars.
Battle_Ravage
05-09-2011, 09:28 AM
I know there are a few, only one I remember off hand is cruise control and the third brake light, if it goes out, so does cruise control.
Anybody know anymore.
And is the calendar on the DIC tied into the radio?
TallassJonG
05-09-2011, 09:53 AM
IDK any but pretty certain that the Radio and DIC are not connected
collier341
05-09-2011, 10:08 AM
ya the radio and the DIC are connected through a data connection. For example, If you were to swap out the stock radio for an aftermarket, you must relocate the stock radio to the trunk to retain the data transfer. Otherwise there is a module you can buy to do it.
Battle_Ravage
05-09-2011, 10:52 AM
Ah, oh well, don't need the calendar anyway. Thanks.
Panther427
05-09-2011, 03:36 PM
Loose your brake position sensor and you loose ABS, Trac Control, Stabili Track, Brake light, your DIC tells you to service brake apply sensor And last but not least you loose Cruise Control.
Battle_Ravage
05-09-2011, 04:45 PM
Same thing with loose battery terminals and bad speed sensor.
gxp-miller-gxp
05-09-2011, 05:03 PM
yeah u can still put in a date but it will not remember it, it relies on the radio for time to change the date and such
Jared07gxp
05-09-2011, 07:56 PM
not sure why, but it you unplug your MAF sensor you lose trac control and the transmission shifts HARD in tap-shift mode
TiredGXP
05-09-2011, 08:20 PM
When the ECU detects a MAF fail, it forces max transmission line pressure - Tough on our glass transmissions, but designed to make you take the vehicle in to GM because you can't stand the hard downshifts. This "feature" can be disabled with a tune. Shifts hard when not in tap shift mode too.
Jared07gxp
05-09-2011, 08:36 PM
hmmm, if unpluggin the maf didnt make the motor run like crap and the transmissions were a bit tougher than they are..... that could be desirable to us that cant afford a tune/ shift kit.
GXP25
05-10-2011, 12:23 AM
This is a true statement.
I recently upgraded to the 2011 Corvette NAV and my date is gone.
I only used the Tech 2 to unlock it and not set it up (if it's possible).
