Here we go ago!?
Here we go ago!?
Well long story short! Water pump started leaking, bought a new one and new thermo, replaced it and now the car overheats!!!! Got all the air out of the system and checked the thermo. It doesnt seem like the coolant is circulating, i.e. no heat in car and when i squeeze the hoses and release i dont feel the coolant rushing through!! I guessing it must be a faulty water pump...(even though its brand new)? Is there anything i might be missing or should check before i take it off and get another one? Any info is greatly appreciated thanks
Yes, i heard the ls1's can trap alot of air bc of the position of the radiator, so i jacked the front of the car up, let it run, turn it off, let it cool and top it off. I did this a few times
no it didnt, but i did some more research and they say the bleeders can get clogged and i drained the coolant to change the water pump and then got called out of town for a week before i could finish it. could a lot air cause the fluid to not flow through the system? i just hope it isnt a head gasket but the car isnt smoking and if it was just the head gasket wouldnt the coolant still flow through the system and there doesnt seem to be any coolant loss
Save the manuals!
A common thing might be the belt routing. Is it slipping? Does it match the routing shown on the sticker placed on the driver's strut tower?
I'd suggest starting by partially draining the system and taking the thermostat out. (If you can.) I imagine this is not possible with a 1-piece thermostat.
What are the brands and model numbers of the pump and thermostat you are using?
