WHat is correct angle for the pinion?
Hey guys i have a Midwest Chassis 9 inch and i took out my torque are during my tranny removal, and when i put it back in i set the angle to 3 degrees, is this correct angle for our cars? I measured the crank at -1 degree and the rear end yolk at 4 degrees. Thanks
well let me put it like this the crank was like this / 1 degree and the rear end was like this \ 4 degrees just to make sure i have the negatives and positives correct
Coal Mining Director
MW is dead on. If the engine is pointing down 1 degree toward the rear, then the rear pinion yoke needs to point down 1 degree. That will allow the joints to align under torque when the rear rotates upward ~2 degrees at wot. Engine will be down 1 and pinion will rotate up to +1 and the joints will be parallel...where you want them.
I put the car at ride height witht he suspension loaded and adjusted pinion, I did put the agf on opposite sides of the car so it would read in the same direction btw. IS THIS CORRECT?
Mainshaft 93 degrees
Pinion 94 degrees
Pinion 94 degrees
Someone posted this website and I think it explains it very well. Mine is at 1.5, but I'm going to pull the driveshaft like this site and confirm.
http://www.rosslertrans.com/Pinion%20angle.htm
