question about new car
i bought this car around a month ago and have some questions
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
i posted the link just to know if any of you guys recognize it or have any information about it at all...would like to know the history of it...
i want to know if it is a real ws6 or not... after searching and stuff i found out that the only way to know is by the code on the sticker on the door , went out to have a look and the sticker wasnt there , any other way to tell?
thanks
thanks
LS1Tech Administrator
Received 1,483 Likes
You can also enter the VIN here:
http://www.compnine.com/vid.php
That should list all the RPOs for you.
couldnt understand the website , non of the "charts?" said that this is for your viechle . ....
this is the vin
2G2FV22G212101949
can you run it RPM_WS6 and tell what u find? thanks
this is the vin
2G2FV22G212101949
this is the vin
2G2FV22G212101949
this is the vin
2G2FV22G212101949
Anyway, I tried it and it worked just fine. I cut and pasted the build date and RPOs that were shown (format is a bit raw, but I tried to clean it up some) below. The "WS6" RPO is not shown. I would double check with a GM dealer and have them run a VIS report for your VIN, just to be sure. Compnine has always been correct in my experience, but I have heard some others mention that they've found descrepancies.
Additioanlly, the car pictured in that ebay link has 16x8" Firebird/Trans Am wheels. Those are not the wheels that would have come stock on a 2001 WS6. Also, the lower air box appears to be that of a Z28/SS/Formula/Trans Am, and not the raised lower box that is specific to the WS6 cars. These are further pieces of evidence that support this car NOT being a WS6.
Vehicle: FIREBIRD COUPE
Year: 2001
Build Date: 2000-07-26
RPO Description Matches
UA6 THEFT DETERRENT SYSTEM ANTI-THEFT (UA6)
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE, VOLTMETER, TACHOMETER, TRIP ODOMETER) GA(UB3)
UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
W55 ENTERTAINMENT SYSTEM OPYION E ENTERTAINMENT SYS OPT E(W55)
Y82 TRANS AM PKG BASE(MERCHANDISING OPTION) PKG,TRANS AM BASE(Y82)
1AY ORDER MODIFICATION - STOCK
1SA PACKAGE-OPTION 01 (1SA)
19I INTERIOR TRIM COLOR (19I) INTERIOR TRIM,BLACK (19I) INTERIOR TRIM,EBONY (19I)
193 TRIM COMBINATION,BLACK LEATHER (193)
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
6ZM COMPONENT FRT LH COMPUTER SEL SUSP (6ZM) SUSP(6ZM)
7ZM COMPONENT FRT RH COMPUTER SEL SUSP (7ZM) SUSP(7ZM)
8TJ COMPONENT RR LH COMPUTER SEL SUSP (8TJ) SUSP(8TJ)
9TJ COMPONENT RR RH COMPUTER SEL SUSP (9TJ) SUSP(9TJ)
AAA STANDARD EQUIPMENT
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IP3 TRIM,INTERIOR DESIGN (IP3)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K43 GENERATOR 102 AMP 102 AMP(K43)
LS1 ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE 5.7G(LS1)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NF7 EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
P05 WHEEL,CHROME CHROME WHL(P05)
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
R7X CONTROL - SALES ITEM NO. 48
R9P CONTROL - SALES ITEM NO. 90
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
T43 SPOILER,REAR RR SPLR(T43)
T78 HEADLAMPS CONTROL DELETE T78)
Internet Mechanic
^ Agreed, looks like a possible rip off or they really do not know what they have.
These also show it looks like a Base Model v8 Trans Am.
Just for a reference, back about 5 years ago when CETA ed. 2002's were showing up as trade ins at dealership. I saw one wanted top $$$ and it had silver twist rims instead of the black rims it came with. I had a chuckle.
f*** ... wth is this
sux :"(
beside the wheels and the air box ... anything else i should know abt?
man this sux ... there is nothing i can do now right?
also if i wanted to contant the guy who sold it , what do you suggest i till him? :@
sux :"(
Sorry man. Still doesn't change the fact that it's a great car. The differences were minimal anyways. Nothing like some new wheels, airbox and exhaust to cheer you up. Just enjoy it is the best I can tell ya. Take off the badges if you don't want to feel like you're posing.
other than this one , i was looking at other t/a's ... the price diff is big between the ws6's and the non ws6 ones ... thats what im mostly upset about!
you can contact him and see what he says. he tells you in ad that he change air box as well as seats. i where he list car info it does say ws6 and in write up he says "this car is basically a low mile original Trans am". look like he may have been being a little sneaky to me(just my opinion). i would never buy a car off ebay without going to see it(again just me). ive only been in car business a few years but i see a lot of shady crap.
other than that its a beautiful car and miles are low. id be happy with it
ya the thing is that the place is called TRANS AM SPECIALTIES!!!! when i walked in there there some gizzlion trans am's and this was the onyl 4th gen ... it looked so beautiful that i didnt think about anything and just bought it.... where does it say the he changed the airbox?
anyone here ever heard about this place?
soo not cool
soo not cool
