Oil pressure sensor and intake problem...
Old 05-13-2011, 12:45 PM
Gordon0652's Avatar
Default Oil pressure sensor and intake problem...
The intake manifold needs to be moved back 3/8" but the oil pressure sensor is in the way...
Any ideas? Not going to cut/weld the manifold.
Pictures attached:
Old 05-13-2011, 02:35 PM
skatnkidd's Avatar
I would use a 45 degree fitting, that would place it right under the manifold and out of the way.
Old 05-13-2011, 06:17 PM
Gordon0652's Avatar
Thats what i was thinking, but where do i get one?
Old 05-13-2011, 07:51 PM
S10xGN's Avatar
I'd angle-cut the tower, rotate the cut piece 180° and reweld it. Wouldn't tkae much of an angle to move the sensor out of the way...
Old 05-13-2011, 08:42 PM
LS1MCSS's Avatar
I've been searching for 45 minutes and all I can say is good luck.
Old 05-13-2011, 08:43 PM
LS1MCSS's Avatar
That sensor has a real thin plastic diaphram in it. Welding will ruin it.
Old 05-14-2011, 01:33 AM
Gordon0652's Avatar
If i can get the thread and pich i'll see if i can get someone to machine me something...
Old 05-14-2011, 10:03 AM
skatnkidd's Avatar
I went to a local speed shop who stocked an entire array of fittings, took some time to find what I needed for the task I had to deal with at the time. It has to be out there, jegs or summit with all their AN fittings should have something.
Old 05-14-2011, 12:39 PM
tommycompton's Avatar
How about a shorter pressure switch?
Old 05-14-2011, 05:48 PM
Gordon0652's Avatar
Part number?
Old 05-14-2011, 07:16 PM
S10xGN's Avatar
Not welding the sensor, just the "tower" part of the valley cover! Did you see the cut-line on the reposted pic? My cover is currently bagged and stored, but IIRC that "tower" looking thing is just that. An extra long tube that the sensor screws into.
Old 05-15-2011, 04:37 AM
HSV-GTS-300's Avatar
Part number?
12616646
AC Delco No D1846A
Height from bottom of seal to top of plastic housing = 37mm
Total end to end length 47.7mm
Old 05-15-2011, 10:21 AM
Gordon0652's Avatar
Originally Posted by HSV-GTS-300
12616646
AC Delco No D1846A
Perfect! Thank You!!! That will fit.
Old 05-15-2011, 06:54 PM
Bouvs's Avatar
Any updates?
I've seen that same sensor and its an LS2 sensor, it has a different connector then the LS1... if this does work someone let me know I'm in a big hurry and have this same issue!
Old 05-15-2011, 08:46 PM
Gordon0652's Avatar
Originally Posted by Bouvs
Any updates?
I just saw that. Three electrodes, not one.
EDIT: i've been reading that the reason for the three electrodes is for a ground, and fuel pump cut off.
Old 05-15-2011, 11:55 PM
Any updates?
It's 3 pins in a T shape.
Fits my 2001 LS1 car harness connector.
Old 05-16-2011, 11:12 AM
Also have an Airtex part number 1S6713
But yes also 3 pin.
Old 05-16-2011, 01:49 PM
Bouvs's Avatar
doesn't fit mine.
Well I've been looking into adapters all damn day without any success so what I want to do is drill and tap the boss on the oil filter housing. If anyone has any reason why I shouldn't do this please let me know right now cause I'm doing it.
So I'm going to drill it, tap it and get an adapter as I think its too small for the original sensor to thread in *there isn't enough metal there to tap it out to M16 thread*. So I'll let you know how this work.
any advice would help!
Old 05-16-2011, 07:29 PM
Gordon0652's Avatar
M16x1.5 male to male -6AN fitting -> 90* female -6AN to female -6AN -> -6AN male to M16x1.5 female.
Old 05-17-2011, 06:49 PM
Bouvs's Avatar
pictures? I'll try and post some up of my solution aswell. The 90* wouldn't have worked for me as I had no direction to orientate mine without it running into something.
Quick Reply: Oil pressure sensor and intake problem...
