Drag Racing Results - new personal best...much love to Circle D!!
608kZ28
05-13-2011, 10:14 PM
went to the drags tonight to try out the 3800 circle d converter. the air was crappy as rain was around the area, track prep was good.
mods are pacesetter long tubes, ory, LM2, sfc, lca, tranny mount torque arm, lid, ls6 intake, p&p the stock heads, cam, and Mickey Thompson ET Street Radial - 275/50R15
best time before the stall
60...2.001
330...5.506
1/8...8.301
mph...87.22
1000...10.747
1/4...12.800
mph...109.99
and after
60...1.645
330...4.935
1/8...7.683
mph...89.48
1000...10.065
1/4...12.079:D:D:D
mph...111.74
608kZ28
05-14-2011, 03:14 PM
really? no comments?
Jersey Mike
05-14-2011, 03:28 PM
Nice cut on the 60 foot. Just curious what size cam you're running, as the mph seems to be on the low end...
transamtom
05-14-2011, 08:26 PM
Congrats 11's are just around the corner:)
608kZ28
05-15-2011, 09:26 AM
its a small cam. i have the specs on it somewhere around here. lol
lavoy
05-15-2011, 11:12 AM
good gains. now if only you could cut a light LOL see yah friday if it dont rain again.
608kZ28
05-15-2011, 01:23 PM
who the heck are you?? lol
shortdog
05-15-2011, 03:52 PM
Nice drop in et, but if you have a cam and p&p stock heads, you should easily be in the 11s which might be one of the reasons why you're not getting alot of comments. You did mention the weather was crappy though..
dee99gt
05-15-2011, 06:23 PM
nice run!
608kZ28
05-15-2011, 06:50 PM
i do have that
shortdog
05-15-2011, 07:15 PM
My mistake, I meant "SINCE" you have cam/p&p heads, not "IF".. However, you still should be in the 11s. As far as your stock p&p heads, it can hurt et/mph if they're not ported right.
lavoy
05-15-2011, 11:49 PM
the weather was very damp rain was all over the area and the wet air was not helping power, that and he cant drive for crap since he is used to his slow cavalier lol.
as to who i am i ill give you a hint, we spoke on face book tonight
608kZ28
05-16-2011, 07:50 AM
you ass!! lol
Wire guy
05-17-2011, 03:23 PM
Your before and after are the perfect example of the old saying what ever you lose in 60' you can double for the 1/4. You dropped the 60' almost 4 tenths and lost .8 over all. I would say that convert was one of the best investments yet. I feel your pain on the air these motors don't run on water and thats all that was in the air that night. Good luck next time and good work Circle D
IllusionalTA
05-24-2011, 05:52 PM
did you put drag radial's on @ the same time as the converter? just curious, we've gone easy 1.5's on stock motor'd car's w/a converter... get some suspension work done and you'll be in the 11's easy...
608kZ28
05-24-2011, 06:19 PM
well yeah. i never would of listed the Mickey Thompsons if i didnt.
and already have some suspension done. some better weather and im there in the 11s
T/ALT1
05-25-2011, 10:26 AM
Everything looks ok except for the mph on both passes before the stall and after u are only picking up 22mph fromt the 1/8th 89.48mph mile to 111.74 at the 1/4 mph. Most cars I have driven/raced pickup 24+mph from the 1/8th to the 1/4mile. So i would start looking for restrictions, I'd start at the throttlebody forward on the intake side(FTRA or SUX2BU)mod helps,then the headers back. JMO MY old cam only LT1 ran 1.64 60', 7.70's@89mph 1/8th, 12.00@113mph with stock heads. I swapped the heads for a ported set (stock valves) and ran 1.58 60', 7.43@93mph, 11.61@117mph. Maybe you are getting knock retard or get it dynoed. Later
608kZ28
05-25-2011, 08:27 PM
it is tuned. everything checks out ok.
not sure why everyone puts so much on MPH. what i mean is, ive seen cars run 13s at 108-110 mph. and ive also seen cars run low 12s at the same mph.
lemons12
05-25-2011, 08:42 PM
What was DA?
With that size converter and mods, car should be in the 1.5s.
Seem to be common with circle D. Anyone k.ow if they flash a little lower than advertised?
608kZ28
05-25-2011, 08:58 PM
What was DA?
didnt look. like i said in the 1st post the air was crappy with rain being in the area. given some good air and ill do 11s easy
lemons12
05-25-2011, 09:09 PM
If you have the slip still... Google drag times da calculator... it will let you know the da as well as corrected times.
608kZ28
05-26-2011, 07:09 AM
i dont put too much stock in those online calculators. but according to that DA calculator it would of been 11.924 @ 113.20 mph.
lemons12
05-26-2011, 10:02 AM
What was the DA?
And that one is pretty spot on usually.
c0ncEpT
05-26-2011, 01:57 PM
http://www.dragtimes.com/da-density-altitude-calculator.php
Plug in the supplied info to see what the DA was.
TravisMcGill2000
05-26-2011, 02:35 PM
Nice gain with the circle d. Whats your raceweight. Your mph diff seems be low for ur mods. You may wana look into that. My bolton lt1 trapped 108.
608kZ28
05-26-2011, 06:53 PM
What was the DA?
511
thats the one i was using
around 3700 give or take. and what would you suggest i look into?
lemons12
05-26-2011, 06:56 PM
511 is actually a very good DA.
There is definitely more in that setup. Race weight Is a little high but that isn't it. I would definitely expect that converter to be In the 1.5 range with given mods.
lemons12
05-26-2011, 06:57 PM
Who tuned the car?
projectX
05-26-2011, 07:03 PM
Hell yeah bro!
TravisMcGill2000
05-26-2011, 07:12 PM
511
1st i would get that pig on a diet. lol Wats your tune look like. Afr, timing, dyno numbers? What are the shift points and gear u are running. U diff got some more in your set up. Youll get in the 11s with ease.
BADHAWK51
05-26-2011, 07:49 PM
Circle D makes a nice converter. Iv'e been 1.42 sixty on that same converter in my car.
608kZ28
05-26-2011, 08:45 PM
i had the car weighed 2 years ago when i 1st got it. ill weigh it again this weekend with me in it since the car and myself lost weight since the 1st weigh in.
a family member tuned my car. he did it before and owns a garage and dyno where he does this for others. im thinking with more practice ill be faster. there is another track in my area which i want to go to if it ever stops raining.
TravisMcGill2000
05-26-2011, 08:52 PM
how hard are u turning the motor
608kZ28
05-30-2011, 02:34 PM
6800 rpm
didnt get a chance to weigh the car either. storms on friday dump 2 inches of water at the track. and saturday their was a bunch of cars by tech and thats where the scale is.
lemons12
05-30-2011, 03:08 PM
Something is up with that setup...6800 rpms with cam ported heads etc etc and a decent converter, should be decently quicker than that.
608kZ28
05-31-2011, 07:04 AM
maybe its the track? i hear it goes up hill some
