Transmission not shifting
Old 05-14-2011, 09:38 AM
sunsetorange's Avatar
Default Transmission not shifting
5.3L / 4L60E in a 2002 Jeep TJ,
PSI Conversion harness
B&M Shifter
Took it out for my first little test drive this morning and found that the transmission wont shift if in DRIVE. It will shift between First and Second if i put it in Second gear but thats about it.
Any thoughts? VSS?
Old 05-14-2011, 10:13 AM
Prorac1's Avatar
Sounds like VSS to me. Id check that first. Eric L
Old 05-15-2011, 09:21 AM
1987earthquake's Avatar
Check to see if you have power at the trans
Old 05-16-2011, 05:05 PM
I do have power at the transmission.
Old 05-16-2011, 06:57 PM
VSS sensor is good.
Old 05-17-2011, 06:48 AM
LS1Tech Sponsor
psiconversion's Avatar
Is the check engine light hooked up and do you have the TCC wired to your brake switch correctly? Please give us a call to discuss. Thanks.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Quick Reply: Transmission not shifting
