What Kind Of Fluid In Your Tick Master Cylinder?
I do know that it has a higher boiling point than DOT 3 Fluid. With the line to the Slave running right past the driverside header, the fluid gets really warm. I use the DOT 4 as added protection against it deteriorating as quickly.
I would run DOT 5 which has an even higher boiling point because its made with Silicone (won't absorb moisture). But, as the post below states, that ****'s not cheap. And with the frequency at which its changed, it would get expensive rather quickly.
Agreed.
yeah, I've read DOT 4 isn't good for seals somewhere but I don't know. I use the valvoline DOT 3&4 fluid, like $6 for 32 oz so it's cheap enough to flush every few months.
