Gears & Axles - want a new rear, cheap 12 bolt?
03impala9c1
05-15-2011, 11:31 PM
i wanna get rid of this 10 bolt junk on my 96 z/28. id like to put a junkyard 12 bolt in and beef it a bit.
what vehicles should i look at for one to put in with the least amount of modifications and what am i going to have to do to put it in. any writeups?
Bob@BruteSpeed
05-16-2011, 07:30 AM
http://shop.brutespeed.com/Brute-Speed-10-Bolt-12-Bolt-and-9-inch-Information-Brute-Speed-Rear-Information.htm
Take a look at the above link. You would be much better off going with a nine inch. You could go with this Moser nine inch housing and axle package, then add a junkyard center section to keep cost down. http://shop.brutespeed.com/Moser-9-Inch-Housing-and-Axles-with-Torque-Arm-Bracket-Moser-Housing-and-Axles.htm Bob
03impala9c1
05-16-2011, 07:36 AM
thats not bad. not bad at all sir. 1190 with the backbrace... hmm... i may just save up for this.
Bob@BruteSpeed
05-16-2011, 07:39 AM
You wouldn't need the backbrace unless you're planning on running deep into the 8's in the 1/4. Bob
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
