10 Second Club - ET Street launch tips??
lstvr
05-16-2011, 01:28 PM
Hi guys, never run a drag tyre before, i have gone 11.1/133.42mph so far on 255/35-18 street tyres, but now have some 260-16 MT ET streets, what tips can you give me to get a 10 outa my beastie!!??
Quick Sh0t xMLx
05-16-2011, 01:44 PM
Air the tires down to like 15 PSI(maybe less), do a nice burnout to get them warm and after that it just depends on the car. Play around with the RPMs and amount of clutch slip. If you're running 11.1s on street tires I'm sure you'll figure it out in no time:nod:
Frozen WS6
05-16-2011, 10:39 PM
I had to make sure I spun them a little harder as I roll out of the box because I seemed to be picking up some water and caused me to spin on the line.
Quick Sh0t xMLx
05-17-2011, 12:39 AM
Maybe you were still slightly in the water box during the burnout?
2slow2flurry-ous
05-21-2011, 07:16 AM
Man that's a sick car dude. Like others have said don't be afraid to air em down to 15 psi with a good heat cycle and let that bitch eat!
Frozen WS6
05-22-2011, 12:16 PM
Possibly. The track people direct you to where they want and each person probably pulls us further forward or back then others.
But any treaded can pick up water as you roll out of the box and if they put too much water down then it will spray into your wheelwells and drip down on the tire as you pull to the line.
We also have the issue of cold track surface temps. On a good day we might see 60 degrees and 40-50 degrees in the spring and fall are normal.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
