t56 vibration?
Old 05-17-2011, 06:38 AM
lbmrider927's Avatar
Default t56 vibration?
I have a lt1 with a t56 and have been chasing a vibration for a long while now. I thought it was a rear end issue but I started pulling wheels axles and such off and the vibration remained and got worse. It is a nine inch but anyway I pulled the driveshaft and put a yoke in the tranny to try that and the vibration was still there. The vibration goes away when I push the clutch in so I swapped the tranny with another one I had and vibration got softer but still remains starts at about 65 and progressively worse all the way up any gear.
ANY IDEAS?
Old 05-17-2011, 08:47 AM
chmilll's Avatar
how old is the actual clutch disk? could be the disk chattering due to wear.
Old 05-17-2011, 11:37 AM
Two different ones, two different engines, two different flywheels, pressure plates
Old 05-17-2011, 01:29 PM
chmilll's Avatar
are there any visible imperfections on driveshaft, i.e.: dents, dings, scratches?
Old 05-17-2011, 01:59 PM
Tried 2 different ones and like I said it does it with just a yoke in the trans
Old 05-17-2011, 02:07 PM
chmilll's Avatar
condition of mounts? and type?
Old 05-17-2011, 02:13 PM
Rubber. And less than 10k miles no cracking or separation.
Old 05-17-2011, 02:23 PM
chmilll's Avatar
whats the condition of the motor? good plugs wires things of that nature? harmonic balancer?
Old 05-17-2011, 02:44 PM
ATI balancer two different engines one neutral balanced forged 383 and now a stock balanced 350 and no vibration with clutch In.
Old 05-17-2011, 02:46 PM
Randal McSandal's Avatar
Pinion angle?
Old 05-17-2011, 03:20 PM
thesource's Avatar
Any gear specifically or just speed related?
Old 05-17-2011, 06:37 PM
Just speed
Old 05-17-2011, 07:02 PM
thesource's Avatar
Where do you feel the vibration at and does it go away when you push the clutch in or remain until it slows down?
Old 05-17-2011, 09:36 PM
65-150+ and I have tried it with no driveshaft and just a yoke in the trans the vibration is there same speed on the speedo and in two transmissions.?
Old 05-19-2011, 11:25 PM
output shaft or any other ideas?
Old 05-19-2011, 11:32 PM
Tx91z28's Avatar
tail shaft bushing?
Old 05-19-2011, 11:36 PM
slowside's Avatar
I am a complete noob, but if its speed related. That rules out drivetrain(because the rear would be constant and trans/engine would be different speeds maybe showing up at the same spot in each gear) except for rear end with axels and such, I know little about rears but I understand that if a rotating part isn't balanced or straight/true its going tell you. The only other places that would matter would be wheel/tire balance, or wheel bearing but the wheel bearing would make a constant sound.
Old 05-19-2011, 11:43 PM
it vibrates without a driveshaft in... leading me to beleave its in the trans, now is there a common issue with t56s or do i just have two t56s with vibrations at the same speed?
Old 05-31-2011, 10:11 AM
chmilll's Avatar
did you find the problem/ a solution to your vibration issue?
Old 07-12-2011, 10:35 AM
Problem is still there and I have friend that had his trans rebuilt and now with it back in it has the same issue as mine
Quick Reply: t56 vibration?
