WTB - LS6 long block New or rebuildable
Wanted to Buy - Rebuildable LS6 Long block.
Stock block, crank and heads. Must be an LS6 in rebuildable condition. Does not have to be running. Can be worn out but no catastrophic damage. Spun or worn bearings is fine. Worn out rings etc... is fine. No broken rods, pistons or cranks.
Ideally looking to spend about $700 for rebuildable LS6 long block, but will consider others.
Email is best. I don't check this forum a lot
Thanks
Dave
david (at) algozine (dot) com
Thanks
Dave
I have a bad ls6 shortblock. I sold the heads recently
https://ls1tech.com/forums/eastern-c...ck-03-z06.html
david at algozine dot com
