User Support & Resources - Mobile Theme - BB 9780
Reaperchild
05-18-2011, 08:17 PM
Thank you for a great job of managing this website for the trolls of the Ls1 community ;)
Blackberry 9780 using mobile theme !
At the bottom of the page ( Normal Version ) only works if I logout of my account & then click the (Normal Version) to return to the default theme,
So the normal version at the bottom till I am logged out & in the login page I click (Normal Version) to return to the default theme.
Please consider this matter urgently to help me.
Thank you
Alawi
JeremyT
05-18-2011, 09:18 PM
I'm a little confused as to the concern. I checked your account and it shows normal. Your account is set to use default theme (not mobile).
However, if you're using the drop-down menu at the bottom of the page, that is cookie based and not account based. It will override your account settings.
Therefore, it will depend on the device you're using and any cookies set as to what theme you will see with the particular device.
Reaperchild
05-18-2011, 09:28 PM
To clarify in detail once more,
Using the mobile theme, Clicking the (Normal Version at the Bottom in Mobile theme) won't do anything (Basicly like I just refreshed the same page & still in Mobile theme) !! << Its supposed to take me to the Default theme =s
I tried typing www.ls1tech.com in the browser again but still opens up in Mobile theme.
The only way I over ran this problem is by clicking(Logout in Mobile theme) then click (Normal Version) TADA ... I'm back to the Default theme !!
Thank you for the fast response =D
JeremyT
05-18-2011, 09:48 PM
Thank-you for the clarification. I now understand the issue.
I believe this is more related to Black Berry, as the feature works on other devices. The Normal Version link, when viewing while using the Mobile mode, and the drop-down menu you see when using the Normal, work slightly different but both alter cookies.
I'll have to do some checking as Black Berry devices tend to have issues with certain java scripts. The Normal Version link is using an "onclick" java event and it may not work on all Black Berry devices.
Reaperchild
05-18-2011, 10:00 PM
Well I hoped I brought something important to your attention & would also demonstrate the problem in a video asap ... I will try clearing my cookies & check too ;)
Thank you
Alawi
my bandit
05-18-2011, 10:51 PM
i have issues with mobile tech also on my bb. from now on i just use the mobile theme but i still have issues (pictures are funky and compressed, when i start and send a pm it doesnt show up in the sent folder but it still sends, and the parts classified section doesnt work)
Reaperchild
05-18-2011, 10:59 PM
I'm no computer wizard but as you can read above BB javascripts are a bit of a trouble makers.
I say stick to default theme ... Oh yea BTW my problem is also the same on www.camaroForums.com ... They use the same mobile them structure. So I'm now sure its not ls1tech.com related ;)
Thank you again for your help =)
dr_whigham
05-19-2011, 06:58 AM
HA!! I thought I was the only one having this issue a week ago! It would do the same to me, and I have an iPhone 4. I'd click to go back to normal version (MUCH MUCH easier to read classifieds that way) And it would just refresh and not go to the normal page. It would just refresh the mobile theme.
Reaperchild
05-19-2011, 07:16 AM
Ok people now this is a temporary fix for BB users ...
Open browser
Go to options
Clear cookies
Goto www.ls1tech.com
(Pop-up) choose if you want mobile theme or not.
Please help spread this info temporarly because many BB users restart their phones(which takes forever) just to get back to Default theme.
I will try to post this problem to blackberry users & see what will fix this trouble.
Thank you Alawi
Reaperchild
05-19-2011, 08:08 AM
I tried camaroforums mobile theme too ... Same problem =(
Started a thread at crackberry forums:
http://forums.crackberry.com/f219/major-forums-problem-616710/#post6341930
Please try to help out sorting this out in some way.
Thankyou
my bandit
05-19-2011, 12:13 PM
my only thing about not using the mobile theme is it takes so much longer to load everything
JeremyT
05-19-2011, 12:47 PM
Your iphone is different. Your issue would have been unrelated. I can only suggest, in your case, it was a corrupt cookie. This is not an uncommon issue with any browser from time to time. Unfortunately, as far as I'm aware, with an iphone, you have to delete all cookies and cannot singly and manually delete any cookies like you can with other browsers when this happens.
99FormulaM6
05-24-2011, 08:52 PM
It did the same thing to me on my G2 with android 2.2. However, logging out and logging back in fixed it. I like the mobile theme, but it is absolutely HORRIBLE for trying to browse the classifieds.
Reaperchild
05-24-2011, 09:02 PM
WERD !!
Too bad made me think MS4 on sale for 60$ today lol
samson_420
05-25-2011, 09:30 AM
Why run the mobile theme? I run android 2.3 on my HD2 and the forum looks perfect in desktop view.
I do that for pretty much all pages now, since 4g around here is quite quick.
01ssreda4
05-25-2011, 03:09 PM
My blackberry does the same thing. After selecting a new theme, I had to clear my cache out, because even after a commanded change to mobile, it would simply load the sight from memory as opposed to refreshing, so it still showed in the previous selection. Im SURE this is a ploy originating from the cell service provider in order to save bandwidth. Going to pages that are in your cache load from your cache NOT from the actual internet. With a live moving website like a forum, you could see how this would be aggravating as nothing ever refreshes.
