4000 Yank stall question
Hi friends, Im very worry about stall converter.
Im from Mexico
Mine is a 98 ls1 A4 Camaro; mods: 233/239 texas speed package, 243 ported heads, no A/C, headers, 3" true duals, 373 gears, M/T tires, repro, all bolts-on.
Before I changed actaully converter, I used a 3000 stall, (usually at 2400 flash=moving), now I can make the the same, no more, a friend told me that I have to prestall? WOT and then stalled again to raise 3500rpms?
My question is:
Since I change my stall, I have worse number of 1/4 mille, like .3 or .4 dec, since then, I´ve tried from 1000, 1500, 2000, 2500, etc, and no results!
Some people told me that my stall and high rpms deads!? and I need to reintall my 3000 converter?
What do u think?
thanks a lot Im very confused!
Im from Mexico
My question is:
What do u think?
try just letting it flash and see how it feels, I run a yank 4k ss in my car, I never stall it up and wait on the light, I personally just wait at idle on the green stab the gas let it flash and go
But can you explain me how flash it? I usually 2000rpm and wait light and wot!.
thanks
thanks
thanks
That's what I do with my FTI. I tried to brake stall it just to see but it doesn't seem to like that. Now I just punch it off idle and it works great.
Basically "flashing" the converter is just flooring it from idle. I'll pull up the staging beam and put my left foot on the brake. When the light goes green I'll let out the brake and at this same time floor the gas. I find it important to use both feet as sometimes the car can creep forward and trip the beams early.
And a question ?
a high stall will affect in 1/4 mille, because some people told me that a hgh stall affect at high velocity, (lost of power) but excellent power at beginnig.??
The higher the STR of a stall("tightness") the more power loss you'll have up top. I assume you have the SS4000 which is a pretty tight stall so you'll have a "decent" amount of power loss. I wouldn't worry about that with your setup. The benefits far outweigh the drawbacks.
Yea you got it, just let off the brake and go WOT with the right instantly. Go try it out and you'll notice it'll probably pull a bit harder. Let the converter do all the work for you
Sometimes I worried about it.
stall it up as high as it will go...gives the best results and just makes sense...where does your car make the most tq/hp thats is where you want to be in the power band...so off idle it takes longer to get there since you are starting at 1k, now if it is brake stalled to 3k you are that much close to making more power off the line and will have a better 60ft...now dont get me wrong a flash will still give a decent 60ft but not the best...
1.29 60fts here with my off the shelf ss4000 in a head cam 346, 3000lbs raceweight car...131mph
