Gen 5 Camaro Suspension Tech - New Welds are in and right rear rubs!!! Grinding needed?
scottywheels
05-21-2011, 08:30 AM
I am going to try and grind the control arm or order the upgraded control arms from speed ink....
DietCoke
05-22-2011, 02:54 PM
Grind them. The aftermarket ones rub worse.
http://www.camaro5.com/forums/showthread.php?t=147837
scottywheels
05-23-2011, 11:12 AM
it was from where the e brake connects...just had to zip tie it
Larry @ AMS
06-03-2011, 11:11 AM
Hey Scotty
seen that issue before and we are looking at options to relocate the e-brake cables to avoid wheel contact
wheels looks sick!
DietCoke
06-08-2011, 11:16 PM
I zip-tied my e-brake to the toe links. Works fine that way. Will probably eventually change to a hose clamp for more security
sweetC5
06-09-2011, 10:34 AM
Are they 17"... I want to try the stock 17" GTO wheels... if they fit over the brake's I am going to cut and box the lower control arm.
