Oil Cooler/Tranny cooler for a L92/6l90e swap into a 67 Camaro
Does anyone have a good suggestion for an oil cooler and tranny cooler for a L92/6L90e swap into a 67 camaro? I know there are some universal kits available through Summit, but thought I might ask first.
Thank you for your help!
Bobby
Bobby
Theres several cooler adapters out there for the LSX blocks. I think LPE , TPIS and others make them. I used a modified truck one. I cut the rubber hoses that ran to the rad. cooler and adapted an lines to it. Then I used a B&M cooler with a fan kit. It has worked great for several years.
On the trans I ran an lines on it also. The trans used 1/8" pipe to 6an adaptors. I then mounted a large plate type cooler.
