coil power?
coil power?
I have a question about witch coil will produce more voltage. I have the stock coils off my 99 ls1 trans am and coils off a 6.0l out of a 2003 2500hd. wondering if the voltage is different for witch one I should use on my engine. Any help would be grate.
Thanks -Will
Thanks -Will
I would assume they would be the same since there really isn't much difference between a 5.7 and 6.0. But honestly it really doesn't matter unless you are making a ton of power and then you would probable want to go aftermarket coils.
The Scammer Hammer
Here's a good thread on it from a while back.
https://ls1tech.com/forums/ls1-domes.../t-114249.html
I actually have a set that should be hitting my doorstep in a day or two. More power... people ask why? I say how about why not?
