LT1/LS1 4L60E shifter cables... same?
Old 05-21-2011, 11:09 PM
95camaro3800's Avatar
Default LT1/LS1 4L60E shifter cables... same?
I need a shifter cable for my 95 T/A. Will a shifter cable from an auto LS1 F-body be the same?
Old 05-22-2011, 12:26 PM
the_merv's Avatar
Yes..
Old 05-22-2011, 03:36 PM
jr79's Avatar
It maybe, but I know the 97lt1 / 4l60e that got swapped in my 95 wound up having a 10mm ball on the shifter lever on the trans. So the cable might be the same but the end might be a bigger diameter that attaches to the trans. If need be I still have the shifter lever with the 10mm ball in my garage if it helps you.
Old 05-22-2011, 04:11 PM
shbox's Avatar
93-02 cables are the same part number.
Old 05-22-2011, 04:13 PM
whytryz28's Avatar
I ran into this problem with mine, got a cable from another year and the end was larger. Not sure if the plastic piece inside is interchangeable but It wouldn't work.
Old 05-22-2011, 06:04 PM
jr79's Avatar
It was fun trying to find a new lever for the trans, I got lucky after all the junk yards ,ebay and everywhere else I checked. Wound up getting one down the street from my house, a shop had a wrecked camaro and lucky for me had the right part. Dealer could have got it but I didnt want to spend the cash.
Quick Reply: LT1/LS1 4L60E shifter cables... same?
