Battery Disconnected long time
Old 05-22-2011, 11:36 AM
CodyBoy's Avatar
Default Battery Disconnected long time
It's been like that for a couple months while rebuilding the engine.
Will it have cleared all the memory in the PCM? Will everything have to relearn now?
Just don't want to be surprised when I start driving it and it wants to die or spit and sputter.
Thanks
Old 05-22-2011, 01:13 PM
PPI Typhoon's Avatar
My guess would be yes. I'm in the middle of finishing my swap and have my battery disconnected often. It has a bit of a rough start for the first little bit, but relearns and all is well after a while (with all else being 100% operational, which is not often in my case )
Old 05-22-2011, 01:20 PM
LS6427's Avatar
Just connect it and go. It will be fine. Nothing should get wiped out or lost. I've had mine disconnected for 1 month and absolutely nothing happened, fired right up and took off.
