please help 4l60e guys
Old 05-22-2011, 12:28 PM
stock98t/a's Avatar
Default please help 4l60e guys
Ok, so i replaced my 4l60e. While it was still on the jack stands I ran it through the gears, the wheels moved and everything seemed fine so I took it off the stands. Then I put it in reverse and the car wouldn't move so I ran through the gears again. Still nothing. I'm hoping you guys can give me some kind of idea whats going on. Thanks for any help.
Old 05-22-2011, 01:34 PM
Moderator
Vince B's Avatar
How is the fluid level and is this a fresh build?
Old 05-22-2011, 08:29 PM
stock98t/a's Avatar
fluid is good trans was used
Old 05-22-2011, 09:17 PM
Moderator
Vince B's Avatar
Pull a cooler line and make sure its pumping fluid.
Old 05-23-2011, 12:03 PM
stock98t/a's Avatar
ok ill do that but before i installed the trans i spun the converter to make sure the pump was pumping do you think a clogged cooler line would cause the prob? and thanks a lot for helping truble shoot this.
