I would like to swap out a rear end from a 2000 firebird into a 95 firebird that has rear drum brakes is it a smiple drop in or is there some changes to be made because of the drum brakes? has anybody done this swap? thanks.
well the main problem is that you will need to modify the brake lines. drum brakes will use a hrd brake line, and disc brakes have a flexible rubber line at the end. other than that is should be a pretty simple swap.
