AIR delete on a 94 LT1?
Yea im trying to. The pump isn't located under the driverside headlight on my car. I think its right below my blaster because that's where both of the lines run to from the exhaust manifold
Its pretty simple to remove...just buy some plugs for the manifolds or cut the stock fittings. I can't remember if there are any codes for the air pump but you can have it deleted off the computer.
So I called napa and autozone asking for an oil drain plug for a 2000 dodge ram 3500 cummins/ M22 drain plug. Napa had to special order for $20 each and autozone was $50!! Antone else get this too? Any cheaper alternatives?
I know the feeling. So regardless of !AIR, the fans would not come on without the AIR relays being pulled?
After reading around, everyone said to buy P/N: BK 7041378 for the M22/1.5 drain plugs. I bought 2 at napa for like $8/each.
They did not fit, the bolt was too thick. So much for that. Now I am trying to find the right size bolt so that I can get it tuned out soon in a mail order tune... did I miss something?
Switched to m18 in 96.
