Will this Pulley pulley work? (PIC)
LS1Tech Premium Sponsor
I would advise against using a three jaw puller to remove your crank pulley! That is a good way to bend your pulley!
Get the one that looks like that "crow foot" in the image above! It is a much better way to go!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
He didn't say what kind of pulley he had. If its stock, then what he pictured is the "famed" Chrysler puller which everyone says works so good. I personally didn't like it. The stock pulley is made for a small 3 jaw type. Some aftermarket pulleys are designed to be pulled with bolts, but obviously that puller wouldn't come close to working. So I am not really sure where you are going with your response. The pulley on the left wont work with a stock pulley, the one on the right is the exact same kind he pictured :shrug:
Good call, I didn't remember about the stock pulleys not having the bolt holes for that crow foot tool. Any of the aftermarket ones I've seen can use the crow foot and I definitely prefer it to the three jaw puller!
__________________
Thanks. I got ahold of a big 5 ton three jaw puller as pictured on LS1howto.com that was collecting dust in my dads garage. I'm sure that one would have been fine but I'm going with the big dog. I'm gonna yank this bitch off tomorrow.
Yes I'm pulling the stock pulley off and the crows foot won't work as stated due to no holes.
