Passengers side (Bank 2) oxygen sensor replacement..
Hey guys,
New to the board even though I've been a lingerer for quite some time. I have a 1994 Z28 and need some help. What's the best way to replace the passenger's side oxygen sensor? It seems hard to get to!
Thanks!
Thanks!
I have a socket, I just replaced the other side the other day. It's not removing the sensor that is the problem, but getting to it is so that I can! Haha. It's pretty much right above the starter, it seems like I'm going to have to remove that in order to get to it.
with stock manifolds you will have to unbolt the y-pipe and take out the starter to get to it. It will be a royal pain to break loose also. Make sure you soak it in PB blaster and you may have to heat it up to get it loose.
