oil pressure gauge??
Old 05-23-2011, 02:20 PM
SSdreamz's Avatar
Default oil pressure gauge??
had the car for years but dont get to drive it much. after shutting the car off, ive noticed the gauge will drop to nothing as i would expect it to, but then it slowly starts to increase to around 40 psi??? is this normal? then i can cycle the key on and off again, and the gauge will drop to zero then slowly climb to 10psi??? anyone elses car do this?
Old 05-23-2011, 02:37 PM
topgeer's Avatar
1998 formula does the same thing. it gets to about 20-30 after i turn it off. not sure if its suppose to but i do know it does
Old 05-23-2011, 05:52 PM
2001NBMZ28's Avatar
Probably normal. After shut off mine stays at the last pressure - about 40 - all other gauges go to zero except that one. On startup goes to zero and quickly returns to above that.
Old 05-23-2011, 08:32 PM
KILLER-LS1's Avatar
yep, same here, i dont know why haha
Old 04-06-2016, 03:17 PM
Sleeper S10's Avatar
I'm glad to find this old post and see a few others share this happen as well.
All gauges return to zero key off including the oil pressure, BUT then the oil gauge slowly creeps up a tad before wresting.
Key on, engine off all gauges zero out.
Key on all gauges work fine.
Quick Reply: oil pressure gauge??
