383camaroz28
05-24-2011, 10:25 AM
Where do people useally mount there bap? Any pics would be nice.
Avengeance
05-24-2011, 01:58 PM
I dont think I have any pics but....
I mounted mine in the trunk area.... looking into the trunk in the "cubby hole" on the left/driver side under the carpet is a plastic removable floor piece. I mounted my BAP right to the underside of that plastic piece. Its a perfect spot because you can literally zip tie the bap to it and right below it is a vent that vents cabin pressure to the outside of the car.... which does allow air flow right near the BAP. There are several body plugs in that area that allows you to feed wiring through nice and easy.
If you need I can take some pics when I get home from work.
383camaroz28
05-24-2011, 02:44 PM
Yeaa thatd be awesome, i see the wireing diagram but dk wat wires to splice into
