satelite radio question
i just got a xm satellite radio and the model is the delphi roady xt and it comes with the normal xm antenna. i have an 02 silverado and i want to use the OEM xm antenna that comes on the 03-06's. can i just cut the xm antenna that came with the radio and splice it to the oem antenna? i dont care if it's the shark fin antenna on the newer chevy's or if it's just the nub looking one. i just dont want to run that xm wire outside. i want it to look like it came with the truck and make it look clean. im capeable of doing what it takes to do this i just wanna know if the oem xm antenna just has one wire to splice into or is it different. i have looked online at pictures and it's hard to tell. ill post up pics of the antennas that i found.
here is a pic of the nub antenna. it's hard to tell if that is a normal wire. it kind of looks like a cable of some sort or iunno. i dont wanna buy it and then not be able to use it.
I'm not really sure about what you are doing, but you did say that you do not want to run the antenna outside the vehicle. I know this is going in your truck, but in my camaro I ran the antenna under the dash so that it is completely stealth. I also still get excellent signal, even with my entire windshield tinted.
Ungrounded Moderator
You never want to cut and splice the cable from a satellite radio antenna - it's a micro-filament coaxial cable that will lose more signal at the splice than you would by mounting the antenna inside.
On the other hand, there is a good chance that the factory antenna cable has a connector that you can plug into your Roady. There were only two types of connectors used and there are adapters available to connect one type to the other. When I did something similar on my wife's Envoy, I only had to remove the plastic surround on the connector to get it to plug in.
yeah i have read that on other forums but looking at that picture it looks like that cable is really short. if i mount my radio where i want to mount it, i only need about 1' length of cable.
