LS3 480HP cheaper alternative???
I want to make swap into e36 bmw and best I can find in stock form is new LS3 with 480HP for 6500$. But, is it here in market any new LS1 tuned engine with 500-550HP for same price (-7000$)? Why LS1? Because all swap kits is for LS1.
thanks
thanks
You want 500 at the wheels or engine?
You can get a bare aluminum block for $1500, rotating assembly for $2000, heads for $1000 and assembly/rest of the parts needed and you will have a 500rwhp bulletproof engine.
Or you can get a low mileage long block for $3000 and do cam + bolt-ons and have a 500 hp engine.
or you could get a complete, with accessories, intake etc 5.3 for $500, then spend another couple thousand on a turbo setup for it.... make a little over 500 at the wheels and keep it safe, or go ***** out with it and push closer to 600....
then again.. thats only affordable if you do most of the swap fabrication yourself. if you're relying on a bolt in kit, you dont need to do FI.
that said, no... you're not asking too much..
you're spending extra money that you dont have to, but what you're asking for isnt too difficult. You just cant do it cheaply.
its not the parts that make it so you cant do it cheap, its the fact you want it NEW that makes it not cheap.
When you say "swap kit", are you talking about physical hardware, or electrical interfaces?
Hardware is the same, and control systems can be adapted. You can most likely go with Gen3 or 4 engines.
You are such a deep thinker....
http://www.gmhightechperformance.com...son/index.html
You can see that the horsepower potential of LS engines is incredible. This will give you a real good idea of what a simple cam swap in an LS3 can do. If you want some real good advice, you're going to have to be more specific about how much you're really willing to spend, what type of driveability you want, any limitations imposed by the e36, etc. That's just my 2cents.
give you a flatter torque line.
Jim
TSP sells a forged LS2 shortblock for 4200 shipped.. put some LS3 heads on it ($700), accessories, oil pan, ls3 intake, injectors, etc ($1000-1200), cam kit ($700) and have a new motor that can take anything you can throw at it should you want to add some nitrous or boost later. I wouldn't pay over 6 grand for a STOCK engine.. just me.
