What connector is this?
So putting my car back together after the cam swap, I couldnt find where this goes. Fans plugged.
I dont remember it being loose unless it was sitting under something.
Any idea?
Any idea?
what all did you remove during the swap?? im assuming radiaor, fans, water pump, crank pulley, timing cover, valve covers..?
it looks like similar to a coil pack connector (those are white though), the only other thing you would have removed with sensors on it it the fan/radiator. some radiators have a coolant level sensor in the radiator, but it definitely isnt a connector like that. make sure BOTH of your fans are connected too
