Automatic shifter knob removal?
Old 05-25-2011, 09:56 PM
sceld71's Avatar
Default Automatic shifter **** removal?
How do you removal this?
Just the T handle
Old 05-25-2011, 10:24 PM
99'CajunFirehawk157's Avatar
Feel/look around the other side you will see a small horizontal slit/groove, stick a small flat blade screw driver in there to pull out a flat "c" clip that holds the handle on, be careful its a small "Oh Jesus" (I call it that cause if it flies off you'll say...) type clip. To reinstall, just reverse the procedure, less than 60 seconds to do!
Old 05-25-2011, 10:38 PM
philsblwnz28's Avatar
use a 3 jaw puller with a impact gun, it is pressed on.......
jk lol
Quick Reply: Automatic shifter knob removal?
