Conversions & Hybrids - Project Vw Passat Rwd - Ls1 - TKO600 ++
PassatV8
05-26-2011, 05:28 AM
Hello..
We are some craysy guys from norway that are building a Vw Passat Stv 2002, with a Ls1 engine and tko 600 gearbox.
The car is a station wagon and will off course hav RWD !!
We need as little help with flywheel , Clutch bellhousing choises ..
What do we need ?
The enginge come from a Transam 2002 mod..
we have the engine en gearbox a Tremec TKO600
witch bellhousin ?
Clutch ?
Flywheel ?
Other parts needed ?
We would be werry happy if somone can help us with this..
Link to pages who sell the part we need is great!
sorry for bad english writing :(
Thomas H.P
Team Psycho Tuning
www.psycho-tuning.no
garys 68
05-26-2011, 07:53 AM
#621 BBC bell housing or Keislers housing with the extra LS bolt hole
Adjustable stud, BBC clutch fork, 1 3/4" long throwour bearing
or
Hydraulic throwout bearing
LS1 clutch/flywheel (99-02 camaro)
or
Sachs 1050 (0.4" thicker) flywheel, 11" BBC clutch
Pop N Wood
05-26-2011, 10:07 AM
I run a TKO with Keisler's bellhousing and their hydraulic throw out bearing. I am running a GM LS7 clutch, flywheel and pilot bearing. Nice heavy flywheel, should get that wagon moving.
My Keisler bell doesn't have the extra bolt hole. Must be an older one.
PassatV8
05-27-2011, 04:42 AM
Where can i get this parts ?
Other than Ebay ....
Any links ?
Pop N Wood
05-27-2011, 05:32 AM
Clutch and flywheel you can get from a chevy dealer or GM direct. Kielser engineering sells a bell, or you can go to jegs, summit racing, pretty much anywhere for an aftermarket unit. Most ship overseas. I imagine there are dozen or more sponsers on here that will set you up with everything in one package.
PassatV8
05-27-2011, 08:56 AM
everything in one package is what im looking for..
Save me freight cost.
i will search the big www for some this weekend.
Thanks for the help so far...
Any other things i MUST do with this motor ? any upgrades that cost little money ?
The ecu is tuned a bit, it`s a guy i norway that have several of ls1 in difrent cars, he say the motor is putting out 440hp now. with a new tune.
garys 68
05-27-2011, 09:39 AM
Everything in one package for a manual z bar linkage. Just get the 26 spline disk.
http://paceperformance.com/i-5146180-pac-1680-ls-4-speed-conversion-kit.html
PassatV8
06-15-2011, 01:19 AM
Ok.
Then we have ordered this :
Bellhousing, QuickTime, GM LS-1 to Ford T-5 or 3550/TKO500-600
Our Tremec TKO600 is a FORD spesific one ( TCET4617 )
Clutch Set/Flywheel, LS series, 11" Kevlar/Kevlar, 26 spline hub No bearings- F/W - LBS 168
tooth
Pilot bushing, SB Chevy 1.094" x .670" id
Hyd T/O bearing, Slip on, GM Muncie, Saginaw, T-10
So now the build of the passat can move on.. :)
PassatV8
06-15-2011, 03:15 AM
Parts and progress of the build.
Transmission - TKO 600
http://psycho-tuning.no/wp-content/uploads/2011/02/tem8se9g00v8klbtgo0z-300x168.jpg
Bellhousing
http://psycho-tuning.no/wp-content/uploads/2011/02/RM-6037.jpg
Radiator. 3" thick.
http://psycho-tuning.no/wp-content/uploads/2011/02/bilde-32-650x485.jpg
Engine in the car.. not mounted yet.
http://psycho-tuning.no/wp-content/uploads/2011/02/LS1-motor-forfra-650x485.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/LS1-motor-bakfra-650x485.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/ls1-motor-i-650x485.jpg
Div pic:
http://psycho-tuning.no/wp-content/uploads/2011/02/22089a94-650x487.jpg
http://i123.photobucket.com/albums/o298/bmw335/e438ac1f.jpg?t=1288455096
http://i123.photobucket.com/albums/o298/bmw335/51c03016.jpg?t=1289054022
http://tapa.tk/mu/4fa1906d-2ce3-5aa1.jpg
http://tapa.tk/mu/4fa1906d-237b-0947.jpg
Now the mounting of engine and tranny starts. Full rollcage after that.. so more pic vil come.
chuckd71
06-15-2011, 04:40 AM
Wow, there's not much Passat left anymore.
Pop N Wood
06-15-2011, 06:38 AM
I was going to say. I thought passats were FWD. Looks like you cut off more metal than you left.
Good project.
You know it is going to ruin the traction in the snow, right? :D
PassatV8
06-15-2011, 06:55 AM
I dont think we have mutch tracktion on tarmac either :)
This car was a 1.9Tdi. at first we had a Audi S4 engine V8 4x4.. but the cost to rebuild the engine is to mutch.. ca $7000 ... pistons, cam, +++
So a Ls1 is a bether choise :)
Front and rear suspension is from a BMW E39 . 530i all aluminium :)
Coilovers ++++ .. The diff is alsow from a 530, but we thinking somthing like a M5 in the future..
Engine will get some breathing help, turbo/supercharger not desided yet..
Any meanings there ? any good kit i the states ?
sjbdeebo2
06-23-2011, 10:50 PM
I thought those subframes looked like they were from an e39
PassatV8
06-29-2011, 07:05 AM
is there any chance a
Eaton M90 supercharger can be mounted on the Ls1 ?
a new intake manifoild ?
PassatV8
08-25-2011, 08:42 AM
Mor pic:
http://psycho-tuning.no/wp-content/uploads/2011/02/1.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/3.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/11.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/12.jpg
Engine sits where it is going to.. gearbox is in..
From the gearbox to the rear dif the shaft is missing 8 cm, so we have to make a spacer.
Project GatTagO
08-25-2011, 11:01 AM
Are you sure that you have enough fuel pumps? :D
Andrew
gMAG
08-25-2011, 04:09 PM
The shifter on the Keisler "perfect fit' is about 2 inches too long!:D
Magnussen from Flakefjord via the US.:cheers:
http://i52.photobucket.com/albums/g25/chungwoon/1.jpg
PassatV8
08-26-2011, 01:29 AM
Andrew
Hmmm.. not sure.. hehehe.. kidding... Yes have just enough, 1 to feed the surgetank an 2 to feed the engine, if 1 fails it`s 1 left to do the job..
And with a Supercharger it will need more fuel.
"gMAG" Where can we get a shifter that is nice... i like oure 50cm long :D ..
We need a shifter, and we need injectors,throttle body and fuelrail..
any good place to shop this ?
shrike
08-26-2011, 06:28 AM
yes, you guys sure are crazy:)
I always thought it would be nice to have an old Scirocco with a LS1 behind the seats.
But this should be way more practical
amazing project and skills!
PassatV8
08-30-2011, 03:08 PM
More updates..
Big radiator fitted in the original passat front plate.. Sitting position just a little higer :)
http://psycho-tuning.no/wp-content/uploads/2011/02/331512_10150358316586125_613026124_10146870_576180 9_o-300x223.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/337621_10150358318016125_613026124_10146880_484894 1_o-300x223.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/325268_10150358303591125_613026124_10146646_177634 3_o-300x223.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/338662_10150358319276125_613026124_10146897_824925 0_o-1-300x223.jpg
For bigger pictures vissit: http://psycho-tuning.no/skien-bil-vw-passat/
and press pictures.
this car wil be wild :)
PassatV8
08-31-2011, 04:08 PM
New pic..
New rims on the car. delivered to day from a sponsor.. 9x18 rear and front.
Stearing an pedals alsow bought to day. will be mounted in permantly later.
To morrow we will show the car to oure main sponsor :)
http://psycho-tuning.no/wp-content/uploads/2011/02/302243_10150264618796056_565051055_7877173_8225693 _n-650x484.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/313350_10150264619501056_565051055_7877186_1796156 _n-650x484.jpg
http://psycho-tuning.no/wp-content/uploads/2011/02/321895_10150359962956125_613026124_10162811_166979 _o-650x485.jpg
(http://psycho-tuning.no/wp-content/uploads/2011/02/316680_10150264620076056_565051055_7877190_2788167 _n-650x484.jpg)
LS1-450
08-31-2011, 04:17 PM
Interesting build. Almost a guarantee that it's the one & only.
PassatV8
08-31-2011, 04:27 PM
We have already thinking of an upgrade :)
It`s more than enough room for a Viper V10 Srt10 engine :D
but we have to get to drive this beast first...
welldonecj7
08-31-2011, 04:34 PM
looks like you guys are doing some nice fab work, who are your sponsors?
PassatV8
08-31-2011, 04:37 PM
The main sponsor is Me and My friend thats builing it. And spend the big money on this car.. :P
But we have a local VW dealer with some money in this project. A local tyres and rims dealer, and some other ho has things we need .. :)
the_merv
08-31-2011, 04:52 PM
That's bad ass..what's the weight goal?
PassatV8
08-31-2011, 05:02 PM
well ... we hope around 1000-1100 Kg..
Original the passat is ~1450kg we have cut out half the car. new suspension is alu +++
with the ls1 engine from a transam thats is ? 1700kg? the engine is carring half a ton less weight :)
PassatV8
08-31-2011, 05:07 PM
Radiator for cooling :
RATBOX
08-31-2011, 07:00 PM
That's retarded! I approve. :D
the_merv
08-31-2011, 07:50 PM
Aluminum Block LS Engines are under 450lbs fully assembled with accessories. That's the number I've heard many times.
welldonecj7
08-31-2011, 09:49 PM
That thing is going to be fun
94LT1TA6spd
08-31-2011, 09:58 PM
:hail:
That will be a blast to drive!
PassatV8
09-01-2011, 05:04 AM
450lbs ~ 205 kg.. ;-). The car itselfe cleen its ca 300kg. 4 man carry the car on the trailer ( 75kg pr man ) so 300kg car + 205kg engine 505kg. So its 500kg for suspension ++ all the extra Stuff .. I Think we can come under 1000kg.
RATBOX
09-02-2011, 01:31 AM
Can't wait to see some videos.
LS1-450
09-12-2011, 01:31 PM
Bump...
Want to keep this thread easy to access. :corn: Any updates?
Irish350
09-12-2011, 03:17 PM
lol didnt realize its a wagon too, this things gonna be so killer.
huge ass radiator; but it looks like you guys made enough room for whatever mods you choose anyway
keep it comin
looks like the mod motor fits in there too :P
midevil1
09-12-2011, 09:02 PM
Race cars.. "bringing the WORLD together". Horsepower and speed IS the International language.
PassatV8
09-13-2011, 07:00 AM
Will post some more pric later..
We still missing some $ to overhaul front and rear subfram/axel, and shop a few things.
And the last 2 weekends we have spendt on racetracks with oure Supra 750Hk and Skyline 450hk track/drift cars.
Need to shop some brake lines and fuel lines.. mount some gauges and so on..
Will be updatet soon :)
the_merv
09-13-2011, 03:08 PM
Ya I'm missing some money too..:lol:
LS1-450
10-08-2011, 08:03 AM
Hey Norway,
Been almost a month & a half without a meaningful update. Anything happening?
gnx7
10-09-2011, 10:59 AM
awesome build! I guess since your summer is soo short you guys build some serious winter projects! Good luck man!
Here is my dream wagon! RS4...... but with an LSx setup and retain the O1E allwheel drive 6spd trans.
ls1fst98
10-12-2011, 06:39 PM
this thing is sick! ultimate sleeper! "Honey, im taking the wagon to get some groceries be back in a minute!"
PassatV8
10-20-2011, 03:58 AM
Hellooooo...
Sorry for the late update.. We have som money issue so it`s not happening to mutche with the car right now. Som welding has beeing done ++
I will take some picture next week.. New parts for the front and rear suspension is next ... and some more welding +++
PassatV8
12-30-2011, 04:43 AM
Some updates ..
a lot of work is beeing done, some of it hard to see.. welding under the car and so on..
rollcage is almost done +++
se pic.. more updates will come..
http://ls1tech.com/forums/attachment.php?attachmentid=332134&stc=1&d=1325241450
http://ls1tech.com/forums/attachment.php?attachmentid=332133&stc=1&d=1325241450
http://ls1tech.com/forums/attachment.php?attachmentid=332136&stc=1&d=1325241450
http://ls1tech.com/forums/attachment.php?attachmentid=332137&stc=1&d=1325241450
http://ls1tech.com/forums/attachment.php?attachmentid=332135&stc=1&d=1325241450
PassatV8
12-30-2011, 04:50 AM
as you can se, benchpress the car is good training
http://ls1tech.com/forums/attachment.php?attachmentid=332139&stc=1&d=1325242078
Good place in front of the engine,, maybe we will fill it up with a huge turbo ore two smaller ones. we have not desided yet, turbo ore supercharger.
http://ls1tech.com/forums/attachment.php?attachmentid=332138&stc=1&d=1325242078
PassatV8
01-02-2012, 08:52 AM
More pic will come.
We really working hard on the car now.. next week maybe we send it to a local exhaust company to get the exhaust build.
3" from the headers an back to two massive exhaustdampers. and the outlet in front of the rearwheels. downwards to the ground.
Race tracks here in Norway has a limit to 100 dB.
PassatV8
01-06-2012, 02:47 AM
Rollcage almost finished..
http://ls1tech.com/forums/attachment.php?attachmentid=333409&stc=1&d=1325839660
http://ls1tech.com/forums/attachment.php?attachmentid=333410&stc=1&d=1325839660
http://ls1tech.com/forums/attachment.php?attachmentid=333411&stc=1&d=1325839660
http://ls1tech.com/forums/attachment.php?attachmentid=333412&stc=1&d=1325839660
Next now is el,fuel and brake lines..
soon start up :)
things left to do:
Seats
Harnes
exhaust
TESTING
paint job
Windows
sponsor decals
PassatV8
01-13-2012, 05:34 AM
More pic
http://ls1tech.com/forums/attachment.php?attachmentid=334609&stc=1&d=1326454245
http://ls1tech.com/forums/attachment.php?attachmentid=334610&stc=1&d=1326454245
http://ls1tech.com/forums/attachment.php?attachmentid=334611&stc=1&d=1326454245
rouseyss
01-13-2012, 01:21 PM
Badass
alitz
01-13-2012, 04:53 PM
some info about the supra?
LS1-450
01-13-2012, 05:53 PM
Glad to see the project is still alive. Thought, maybe you guys had gone broke.
MMMPSHH
01-13-2012, 06:04 PM
awesome
PassatV8
01-14-2012, 12:57 PM
Witch supra ? Its two of them in the garage.. The Biltema one has info on our web site . www.psycho-Tuning.no
The black one is one we are building rollcage in. Have a 2jz in it with 600hp.
We Are broke ;-) but lucky us the sponsors have som more money they will spend on us...
PassatV8
01-16-2012, 02:44 AM
The car is ready for exhaust build..
Next thing to do after that is starting the enginge ;)
http://ls1tech.com/forums/attachment.php?attachmentid=335165&stc=1&d=1326703378
http://ls1tech.com/forums/attachment.php?attachmentid=335166&stc=1&d=1326703378
chuckd71
01-16-2012, 03:09 AM
That's pretty neat.
turbinesurgeon
01-16-2012, 07:03 AM
That cage blends in nicely with the doors back on, and the rest of the car looks real clean. That thing just screams sleeper. Keep up the good work guys, very nice build.
V8Rumble
01-16-2012, 09:57 AM
This build is just INSANE!! (In a really good way!) :D Keep up the good work, guys!! :cheers:
Golfrallye
01-17-2012, 08:56 AM
http://img.tapatalk.com/4fa1906d-7d59-f9f3.jpg
http://img.tapatalk.com/4fa1906d-7d70-11bd.jpg
http://img.tapatalk.com/4fa1906d-7d87-61f6.jpg
http://img.tapatalk.com/4fa1906d-7da0-b09c.jpg
http://img.tapatalk.com/4fa1906d-7db5-b4e4.jpg
http://img.tapatalk.com/4fa1906d-7dd1-2461.jpg
http://img.tapatalk.com/4fa1906d-7de0-3971.jpg
http://img.tapatalk.com/4fa1906d-7dff-e7cd.jpg
Golfrallye
01-18-2012, 06:33 PM
Here is a movie from the exhaust system. http://www.sviddgummi.no/27797/timelapse-film-fra-eksos-bygging-til-passat-rwd-v8-prosjekt/
PassatV8
01-19-2012, 08:26 AM
We have got a lots of parts these days, so thing is going foward.
The engine is set to start this weekend. :D:D
Paint job on the car is set to Monday 6/2... 17 days from now. :eek2:
so i think we have to camp on the workshop until we are finished....
PassatV8
01-20-2012, 01:09 AM
Spacer betwen diff and midaxel
http://ls1tech.com/forums/attachment.php?attachmentid=335837&stc=1&d=1327043214
Fuel system
http://ls1tech.com/forums/attachment.php?attachmentid=335838&stc=1&d=1327043214
Gear shifter in progress and handbrake..
http://ls1tech.com/forums/attachment.php?attachmentid=335839&stc=1&d=1327043214
Schitzo
01-20-2012, 02:12 AM
I like the integration of E39 subframes into the passat. Looks good.
LS1-450
01-21-2012, 11:14 AM
Thanks for the updates. Looking great!
PassatV8
01-23-2012, 02:57 PM
It`s alive ;-)
Awsome sound
PassatV8
http://www.youtube.com/watch?v=xAZAfj7CXYk&feature=youtube_gdata_player
Golfrallye
01-24-2012, 12:02 AM
http://www.youtube.com/watch?v=lvrXMEjL-_c&sns=em one more movie from the startup
PassatV8
01-26-2012, 05:12 AM
Can someone tell us witch supercharger we can fit on this engine ? We may have a Vortec V2 on the hand for a $1200.
Ore would anyone recemend somthing else ?
Tig
01-27-2012, 03:13 PM
That looks and sounds amazing.
Great work guys.
PassatV8
02-08-2012, 01:46 AM
The car is finaly at the paint shop... white no gloss.. and black details/decals ...
PassatV8
02-22-2012, 04:39 AM
the car is finished painted today..
This is pic from the rollcage... now we have to put it together :)
http://ls1tech.com/forums/attachment.php?attachmentid=341493&stc=1&d=1329907056
http://ls1tech.com/forums/attachment.php?attachmentid=341494&stc=1&d=1329907058
LS1-450
02-22-2012, 06:32 AM
Thanks for the update. Did the customer request the roll cage or is the cage required for a specified class of racing?
As to the supercharger; it's best to check the forced induction section. Those guys have the most experience & can answer all of your questions correctly the first time.
PassatV8
02-22-2012, 07:12 AM
The car is our :)
We must have roll cage in order to get a license on the car. We use it on a track in Norway. Drag, drift and so on.
This car is bulid to use hard.. we have a tire budget on ca 80 pairs of tires...
so let the smoke come.. :)
7969
02-22-2012, 10:03 AM
Sweet build ,cant wait for the tire smoke!!
PassatV8
02-27-2012, 02:05 AM
http://ls1tech.com/forums/attachment.php?attachmentid=342153&stc=1&d=1330329618
http://ls1tech.com/forums/attachment.php?attachmentid=342154&stc=1&d=1330329618
http://ls1tech.com/forums/attachment.php?attachmentid=342155&stc=1&d=1330329618
http://ls1tech.com/forums/attachment.php?attachmentid=342156&stc=1&d=1330329618
http://ls1tech.com/forums/attachment.php?attachmentid=342157&stc=1&d=1330329618
http://ls1tech.com/forums/attachment.php?attachmentid=342158&stc=1&d=1330329781
http://ls1tech.com/forums/attachment.php?attachmentid=342159&stc=1&d=1330329781
http://ls1tech.com/forums/attachment.php?attachmentid=342160&stc=1&d=1330329781
http://ls1tech.com/forums/attachment.php?attachmentid=342161&stc=1&d=1330329781
PassatV8
02-27-2012, 07:11 AM
http://ls1tech.com/forums/attachment.php?attachmentid=342171&stc=1&d=1330348269
http://ls1tech.com/forums/attachment.php?attachmentid=342172&stc=1&d=1330348269
TTLS1GP
02-27-2012, 01:26 PM
looks fantastic.
Look forward to video's of it thrashing the track!
bigpapi211
02-27-2012, 11:43 PM
this thing is downright the craziest thing i've ever seen. I wanna do this to my GFS passat
Kaane
02-28-2012, 12:28 AM
What passat? There is no passat left here lol, it's like a nascar car with Camry sheet metal :)
PassatV8
02-28-2012, 02:52 AM
Its look likes a nascar with that front ;-) hehe
Golfrallye
03-15-2012, 08:03 AM
http://www.ta.no/motor/article5971840.ece
Project GatTagO
03-15-2012, 08:46 AM
Great to see progress on this project.
One thing to consider is the air intake system. LS engines are very sensitive to high air intake temperatures. When AITs go up above 130-140 the computer will start pulling timing very quickly and you can easily loose 15-20 HP. You current system is sucking hot air right behind the radiator.
I would consider making a air intake system that has one tube that goes to the passenger side and down, and pick up cool air from in front of the front tire, outside the engine compartment.
Andrew
95batmobile
03-15-2012, 09:26 AM
how much does the car weight? put a blower on ittttt
PassatV8
03-20-2012, 03:41 AM
The car weight is ca 1200 kg . We want a blower , but the budget is blown ;-( . With a airduct it will get cold
PassatV8
03-20-2012, 03:42 AM
It will get cold air with a airduct i think.
PassatV8
04-02-2012, 08:19 AM
Video of the second test drive..
http://youtu.be/oe_OQ-irXvk
Skip Intro
04-03-2012, 11:11 AM
Such a wonderful sound. Tires everywhere should be trembling in fear by now.
PassatV8
04-20-2012, 12:44 AM
Magnacharger mp112 is next on this car. just have to rebuild beltdrive to corvette styl to aligne the pulley from the supercharger to engine..
http://ls1tech.com/forums/attachment.php?attachmentid=350336&stc=1&d=1334900469
http://ls1tech.com/forums/attachment.php?attachmentid=350337&stc=1&d=1334900469
Tig
04-20-2012, 02:20 PM
Awesome.
Congrats on the blower. This is going to be one insane Passat.
LS1-450
04-20-2012, 03:52 PM
I'm so jealous. Great work!
PassatV8
06-04-2012, 05:30 PM
The car is now supercharged :-) look at video , starting in 4th gear ,burnout from standing still.
https://fbcdn-video-a.akamaihd.net/cfs-ak-snc7/v/438599/812/10151801963920721_6981.mp4?oh=c713878f0e426e6e2ac4 81da6e3365e4&oe=4FCD4F20&__gda__=1338855200_0417baa5a0fc3d1705b4a731f02bb7f e
PassatV8
06-04-2012, 05:32 PM
Dyno results: 423whp @ 5200 rpm and insane 650Nm @ 3200rpm we have 460Nm at 2000rpm
SS-TEN
06-04-2012, 08:15 PM
Just found this thread. Love to see LS enthusiasts across the pond! Great build guys. Love everything about it. Could you guys do widebody in the rear and get some 11" wheels? Seems like a lot of work though. Cheers!
PassatV8
06-06-2012, 06:22 AM
Dyno :
http://ls1tech.com/forums/attachment.php?attachmentid=357719&stc=1&d=1338981589
Have to fine tune it for it to run 100% safe.. Cam install will happend soon.
http://ls1tech.com/forums/attachment.php?attachmentid=357720&stc=1&d=1338981589
Video link is not working i think, its on FB. a youtube video will come...
this car is insane to drive :)
PassatV8
06-08-2012, 07:39 AM
http://youtu.be/TfzzOJ9GBcE
4th gear burnout. tiers blows up :)
PassatV8
09-19-2012, 04:42 AM
We have now run a few hours on the court this summer :)
I'm super happy with how the car is running, a good balance and grip. But after we mounted supercharger and have 650nm@3500rpm on the wheels, the car spins over all the track :)
The next step is 1bar pressure, E85 konventering and a new tune on the engine.
PassatV8
09-19-2012, 04:54 AM
New rims on the car for show use :
20x10.5 (265/40/20) on the rear and 20x9 (235/35/20) in the front.
Other upgrades in the winter is widebody in the rear (get the wheelarches uot a bit) and a little bit in the front, new stearing angel, space out the rims 20mm in front and 20mm rear..
We have a new designe on the car as well..
more pics and vids :
http://www.oijoij-hd.com/images/mUcBK.jpg
http://www.oijoij-hd.com/images/9t6fq.jpg
http://www.oijoij-hd.com/images/VQN7.jpg
http://www.oijoij-hd.com/images/PwneV.jpg
http://www.oijoij-hd.com/images/xtJFK.jpg
Burnout 1
Burnout 2
PassatV8
11-06-2012, 03:22 AM
So what do you think?
clutchpack
12-23-2012, 04:11 PM
Just found this and Ho-lee-crap is this awesome. Im planning my own setup like this. Im not planning to stuff the engine as far back as you did so I can retain the interior. Not sure what im doing about the rear. E39 rear driveline? Im wanting to leave the car looking factory untill you open the hood for the shock value on the street.
PassatV8
05-11-2013, 01:11 PM
We finnaly got it on the dyno :-)
715Nm and 495whp @4500rpm
Allreddy at 1800rpm the supercharher produce
600nm on the rearwheels
Video : http://www.youtube.com/watch?v=AFNieGiZ_UA&feature=youtu.be
5.3-on-steroids
05-11-2013, 11:17 PM
Awesome build. Love it!
