12 Second Club - 12.5 Stock Rear still holding up......
Camaro9969
05-26-2011, 06:47 AM
Took it to the track wanted to make a run w out the drag radials so if it blew i could at least of had a run haha. So ran 13.1 w a 2.24 60ft (awful i know) then w the DRs i wanted to just come out of the hole not spinning and ran 13.0 w a 2.2 again so the last run i hit it a little harder ran a 12.5 w a 1.99 60 ft at 112.89 mph. So the car has the power i'm guessing to run a 11.99 i just bought a "back up 10 bolt" just stock got it for 200 so i will push this stock one very hard and try to get flat 12's then if it blows i'll throw the other 10 bolt in and just wait for the 9" to run it again. Not bad so far just not sure how much the 10 bolt will hold haha Maybe high 11's??????
Pic With the M/T ET Streets haha
http://i39.photobucket.com/albums/e151/Gsxr1000Z71/camarodr.jpg
got-a-ls1
05-26-2011, 08:16 AM
im an auto.. yea makes a difference im sure... and i have had mine to a 7.0 in the 1/8th which is a high ten low 11.. and i dont even know how many hard launches at the track with low 1.60-1.62 60's.
blk/slvr02ss
05-26-2011, 08:19 AM
It all depends on how the track is hooking,How weak the rear is how good the clutch bites on how long it will last !!!!!!A Stud Girdle Rear Cover helps a little also !!!!!
zracer323
05-26-2011, 09:11 PM
You realize the ten bolt isn't made of glass right? Put a stud girdle on it, change the fluid regularly and it can last a long time behind an auto.
Mike Morris
05-26-2011, 10:55 PM
Weld the axle tubes as well.
