vacuum leak 97 camaro
there is some sort of air leak around my throttle body that i cannot find. pulled the throttle body replaced some hoses but still nothing. has anybody had the same issue? any suggestions??
i did the brake cleaner trick. and it came from under the throttle body. i replaced a cracked hose running from the intake manifold under the throttle body to the pcv valve. also replaced the throttle body gasket and cleaned the throttle body. but still no luck
when i smoked i used to get a cigar smoking real nice and move it around the area at night time while shining a light on it. really easy to see where the smoke is being pulled in in the light.. im sure theres better ideas then that though lol. not sure what brake cleaner trick your talking about
