12 Second Club - 12.09 w/bolto on's
346ci
05-26-2011, 11:34 PM
Ran my 98' Z-28 on the 21st and I am happy. Car has; lid, longtubes, ORY, loudmouth, unerdrive pulley, 3600 stall, built trans, subframe connectors, tubular rear LCA's, drag radials, stock 3.23 gears, full weight, stock springs and shocks, no a/c, and a 160k miles.
Only got 3 passes in, my first 2 were a 12.72 (spun) and a 12.23 (dropped the tires to 15 psi). My final pass was as follows...
DA was 72
Reaction .0378
60ft. 1.7662
330ft 4.9851
1/8 ET 7.7172
1/8 MPH 90.17
1/4 ET 12.0992
1/4 MPH 111.62
I think I could have squeaked a 11, but I didn't get a chance to run again. Here's a video of my quickest run, didn't get the last part of the pass, camera ran out of memory :bang:
http://i247.photobucket.com/albums/gg142/nat777/th_Nathaniel1209.jpg (http://s247.photobucket.com/albums/gg142/nat777/?action=view¤t=Nathaniel1209.mp4)
blk/slvr02ss
05-27-2011, 06:48 AM
Nice !!!!!!!!Stalled Auto's Rule !!!!!!!!!!!!
green28
05-27-2011, 08:59 AM
Good run, I've got pretty similar mods and ran about the same time last year. I know mine has 11's in it as well but didn't get to make another clean pass. You can hit that 11 easy with another clean pass. What was the DA?
Fast T
05-27-2011, 08:39 PM
Very nice :nod:.
346ci
05-27-2011, 11:26 PM
Thanks guys, the DA was 72 according to the drag times website. I hope to put in some 3.73's this summer and hit some high 11's
TTA850
05-28-2011, 08:26 AM
Nice, there's 11's for sure if you get those shorts where they should be. My '98 T/A went 12.08 at 110 with a 1.56 sixty with similar mods and 3.73 gear/4000 converter. What's your raceweight? Mine comes in at just over 3800lbs with me in it (180lbs).
Congrats on a great running '98 :thumb:
TheBlueKnight
05-29-2011, 03:31 PM
Congrats. So many people look at me like I don't know crap when I say a full bolt on auto 4th gen can run 11's in good DA. If you would have taken out your passenger seat, rear seat, spare tire/jack, and ran a super low tank of gas (maybe even removed from swaybar) you would have had 11's for sure!
TheBlueKnight
05-29-2011, 03:32 PM
Do you have a ram air like the FTRA, Chris1313, SSRA?
stock98t/a
05-31-2011, 03:31 PM
has the car been tuned?
346ci
05-31-2011, 10:22 PM
Thanks, that's a pretty good 60' you got there. I weighed my car at the local dump so I'm not sure how accurate it is, but with me and less than a 1/4 tank it weighed 3550lbs
Ha ha, had a couple people ask what was in my car, they looked surprised when I told them it was just bolt ons with a stall. By the end of the year I will remove the front sway bar and seats just to see what she'll run. I try to race in street trim as much as possible though so I know my street performance is as close to track performance as I can get.
No I don't, just the free ram air mod (holes cut in the bottom of the air box)
Yeah, I tune it myself with HP tuners
Mike Morris
06-01-2011, 05:11 PM
Don't waste your time on gears.
You can do it with your existing mods in better air. Work on traction!
JonCR96Z
06-01-2011, 05:21 PM
Your 60' sucks. Get that down and it'll be a lot faster.
346ci
06-01-2011, 10:45 PM
Will definitely work on traction
Ha ha I like how direct you are, I will try and get my 60' down
1Bad97WS-6
06-01-2011, 11:02 PM
Nice times man..work on your 60ft.. every tenth better on the 60ft is 2 tenths better in the 1/4..
Austin95
06-02-2011, 10:34 AM
What HP tuner did you buy? Are they easy to use?
TheBlueKnight
06-02-2011, 11:08 AM
Yeah your 60ft does suck, you should practice and get a nice 2.3 60ft like me. (sarcasm) :jest:
MonmouthCtyLS7
06-03-2011, 06:58 AM
Nice times
Golf&GM
06-03-2011, 10:37 AM
Damn that's a hell of a view! Must be nice.
346ci
06-04-2011, 12:23 AM
That's what I've heard, hopefully I can get the 60' down into the 1.6's
Ha ha right, I was getting 2.2-2.3 on street tires
I have the HP Tuners Suite. As far as ease of use, that is very subjective. It can get overwhelming fast, but if you take your time and research it isn't rocket science to do on a bolt on car.
Nice times
Thanks
It is a killer view with the track sitting a the base of a mountain, one of the most scenic drag strips I think
pat-ls101
06-04-2011, 08:07 AM
Great times man! What has your car dyno'ed?
346ci
06-07-2011, 03:58 PM
Thanks, have not had the car on a dyno with mods.
blk/slvr02ss
06-07-2011, 06:17 PM
Do a Adjustable Torque Arm and No Front Swaybar and 11's w/ no Problem !
ss1le02
06-14-2011, 11:40 PM
A good CAI would most likely get you into the 11's. Since you have the AC removed the SSRA Mega Mouth would bring in a lot more air. The Mega Mouth is similar to the regular SSRA, in that it has a scoop, however it's much larger since people with no AC have removed the condenser. This frees up a lot of room.
98TADRIVER
06-15-2011, 11:28 AM
gotta love those stalled autos!
346ci
06-18-2011, 11:35 PM
Yeah, considering getting one since they are relatively affordable and seem to have solid results
They definitely serve there purpose in drag racing:nod:
philsblwnz28
07-04-2011, 08:40 PM
get some weight outta there....Im down to 2980, so there is alot to off crap to take out.
senicalj4579
07-06-2011, 09:18 AM
Take some weight out and your 60' will drop. My 60' dropped from 1.7 to 1.6 by taking out around 150lbs or so. The times in sig are in +500 DA on 275 40 17 zr1s all around and mt drs in the rear.
Dont underestimate a good cai kit. I really like the ssra. I have ssra megamouth coming on fri seeing how I deleted my a/c. I will have 11s in the fall no problem.
