patriot stage 3 heads
Old 05-27-2011, 03:07 AM
sky
sky's Avatar
Default patriot stage 3 heads
What u guys think about patriot sage 3 heads on a stock ci. 5.3? Mods are 227/234 tr cam, LT, 3" flowmaster 44's exh, CAI, Ls6 INT, and a EFI tune. Hit Squad Racing
Old 05-27-2011, 09:01 AM
707chance's Avatar
Default Heads
I would talk to sittingmoose about upgraded heads. I kept my stock heads and did a light port, valves reset and shaved .001
Old 05-27-2011, 10:26 AM
fieroguru's Avatar
That is probably the biggest cam anyone has put in an LS4... care to share the specs from the cam card?
Old 05-27-2011, 11:39 AM
DavidGXP's Avatar
I would stick with 2.00"/1.55" The 3.78" bore is very small and bigger valves cause shrouding problems.
You might wanna consider CNC ported 243's
http://texas-speed.com/shop/item.asp?itemid=649
http://www.advancedinduction.com/AiProductsGMLS2.html
https://ls1tech.com/forums/dynamomet...nths-5mph.html
http://www.trickflow.com/partdetail....0&autoview=sku
I'm a big fan of smaller intake runner port volumes. Anything past 230cc is a little big for a 5.3 mild cam buld that will spin to 7000 RPM. The heads you have listed our 237cc.
Without knowing the spec's of the cam I'm going to say it's way to big for a street driven 5.3 that has to push 3800 lb car around with 2.93 gears.
