need some gasket pt numbers/links
Old 05-27-2011, 10:45 PM
03impala9c1's Avatar
Default need some gasket pt numbers/links
looking for a nice stiff leak free gasket for my oil pan and a front timing cover set for the 96. im blocking off the water pump outlet so thats not important but i need the seals for the opti, timing cover, and crank. im guessing im going to want to go gm for that kit.
part numbers or links?
Old 05-27-2011, 11:10 PM
5_LTR_ETR's Avatar
shbox posted these for me the other night
1995-1997 front cover opti seal 12552428
1993-1997 front cover crank seal 10128316
1993-1997 front cover water pump seal 10217886
1993-1997 front cover gasket 10128293
1993-1997 water pump gasket (2) 10128343
1993-1997 water pump drive shaft o-ring (2) 12553792
1995-1997 optispark o-ring (2) 10474278
Old 05-28-2011, 12:26 PM
BALLSS's Avatar
FelPrro timing cover gasket kit # 45956 at most auto parts stores for about $10 has all the gaskets/seals listed above. FelPro also makes a pan gasket they should have for around $25
