Need help please with cam situation. Only experience advise!!! Thanks
I have been told that this cam is not one to produce HorsePower... A max of 30 or so.
What cam could i use in 02 ls1 trans am that will be decent, that i can use, using the same internal components and spring kit i already purchased.
Desperately need your input and honest opinion on this one.
CAM below is what i have but not yet installed...
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 800-5,800
Intake Duration at 050 inch Lift 206
Exhaust Duration at 050 inch Lift 212
Duration at 050 inch Lift 206 int./212 exh.
Advertised Intake Duration 259
Advertised Exhaust Duration 265
Advertised Duration 259 int./265 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.515 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.522 in.
Valve Lift with Factory Rocker Arm Ratio 0.515 int./0.522 exh.
Lobe Separation (degrees) 112
Camshaft Gear Attachment 3-bolt
Computer-Controlled Compatible Yes
Grind Number XR259HR
Valve Springs Required Yes
VALVE SPRING KIT AS FOLLOWS...
Brand COMP Cams
Manufacturer's Part Number 26915CS-KIT
Part Type Valve Spring and Retainer Kits
Product Line COMP Cams High Performance Valve Spring Kits
Summit Racing Part Number CCA-26915CS-KIT
UPC 036584225478
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.290 in.
Damper Spring Included No
Spring Rate (lbs/in) 313 lbs./in.
Inside Diameter of Outer Spring (in) 0.650 in.
Valve Spring Style Beehive
Coated No
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Lock Groove Quantity 1-groove
Lock Material Hardened steel
Brand COMP Cams
UPC 036584225478
Coated No
Locks Included Yes
Lock Style 7 degree
dude if you looking for a good cam that produces good hp and has great street manners..
something like a 224/224 or even a 228/228 for something a little more aggressive.
the cam you have listed is a small cam, not much bigger than stock or a ls6 grind.
both cams sizes I listed are very common cams choices for guys that want excellent street manners but some extra hp and fun.
if you start going as large as my cam 231/237 the car starts becoming less and less of a daily driver...
when picking a cam...
you have to ask yourself, how big are you going to build your car, what are you goals for hp, and how do you drive your car..
once you list that people can more easily suggest a cam
