Replacing monsoon deck
Old 05-30-2011, 11:23 AM
J-Jones's Avatar
Default Replacing monsoon deck
Soon i will be replacing my monsoon deck but what stereos should i get since the monsoon is a little different than other stereos
Old 05-30-2011, 04:14 PM
Ungrounded Moderator
WhiteBird00's Avatar
There is no difference between a Monsoon head unit and any other GM/Delco radio of the same era. All you need is the aftermarket head unit of your choice, a mounting kit, a wire harness adapter, an antenna adapter, and about an hour to install.
Old 05-30-2011, 05:52 PM
JrodCamaro's Avatar
Question on this topic, I'm about to do the same. Last 3 F-Body's had a big plastic panel that went up around the vents and everything, popped right off (97 camaro 94 firebird 97 camaro) Now 99 TA the plastic piece around it is much smaller and seems pretty well secure, any tips for getting this off? I don't want to break the little f*er
Old 05-30-2011, 08:22 PM
The trim is held in place by by four spring clips - two on each side. Simply wrap a soft cloth around a screwdriver to prevent scratching and pry it off.
Old 05-30-2011, 09:57 PM
JrodCamaro's Avatar
Ya after posting on here I figured I'd just have at it, it was off in 20 seconds, lol. Now to get a mount and wiring harness, goodbye steering wheel controls
Old 05-31-2011, 09:22 AM
You do not have to give up steering wheel controls just because you install an aftermarket head unit. Almost every recent HU that has a wired remote port will work with the steering wheel controls using the appropriate adapter.
Old 06-01-2011, 08:11 PM
LS1121's Avatar
Buy the Sony GT-700 it is an HD radio the sound is sooooooo much better that plain FM.
Old 06-01-2011, 08:20 PM
focus12221's Avatar
I dont think sony makes a great headunit to be honest.. alpine, kenwood, panasonic..
http://www.avsforum.com/avs-vb/showthread.php?t=883994
Just to point out that HD radio will add channels but quality is not as good as boasted!
Last edited by WhiteBird00; 06-02-2011 at 07:18 AM. Reason: Merge consecutive posts
Old 06-01-2011, 09:20 PM
LS1121's Avatar
Well I don't think you know what you're talking about, just if we are thinking here.
The guy asked a question and I answered him.
Old 06-03-2011, 03:11 PM
Copy & Paste Moderator
VIP1's Avatar
You can pull off the 4th-gen radio surround/trim by hand and a video of me doing it is in the FAQ.
Old 06-05-2011, 11:41 AM
kevindglenn's Avatar
This should be a pretty straightforward swap...and it'll be be worth the little bit of effort.
