Corsa Tips rotating... :(
I have the 3.5" quad tips setup. The passenger side tips keep walking out and rotating around the pipe out of the muffler. Those babies are as tight as can be, but I can push down on the inner or outter tip and rotate them in that direction. They will also do it after driving the car anywhere around 25+ miles. Anyone else experienced this problem? I can't believe the cam shake would cause this. I thinking something is up with the clamp. Do you all think Corsa would replace it under their lifetime warranty?
Spot welded mine. If nothing else it will keep them from walking or walking away in someone else's hands. I wouldn't be pushing down on them either.
good luck with it.
good luck with it.
I think I found out that tight wasn't tight enough! Lost one of my corsa tips on the motorway doing about 90mph & It just flew off & went bouncing away trailing sparks everywhere! went back & recovered it from the side of the road and it was trashed, luckily corsa sent me a replacement.
But yeah! They don't move now! those brackets take a lot of torque so just pretend the bracket is Justin biebers neck(which really shouldn't take much effort) & go for it.
