do front adjustable shocks/struts lower the car
Old 05-30-2011, 07:48 PM
vbls's Avatar
Default do front adjustable shocks/struts lower the car
i was looking at buying the single adjustable QA1 hal front shocks with 300# springs, will these lower my car?? i want the race stars 15x3.5" front skinnies but i dont want the gap that comes with them
Old 05-31-2011, 09:24 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Most the aftermarket shocks come with a threaded shock body that use a special spring that will allow ride height adjustment by raising or lowering the lower spring mount. You may also want to look into a different brand of shock vs the QA1s... they are an "ok" shock, but dollar for quality the Strange and Afco shocks are a much better deal. We can get you into the Strange shocks for usually the same or less than the QA1s even, and you get a much better shock.
Old 06-02-2011, 04:55 AM
vbls's Avatar
do the strange shocks work the same way, with adjustments???
also do u get to pick the spring pounds like the qa1?
Old 06-02-2011, 10:40 PM
libertyforall1776's Avatar
I assume your goal is shocks *just* for the strip and are not interested in handling?
Old 06-05-2011, 11:57 AM
kevindglenn's Avatar
Yes, I believe that this will do exactly what you're wanting to do.
Old 06-06-2011, 10:49 AM
ssvert99's Avatar
Yes... there are several spring rates available and the shocks are externally adjustable. The Strange shocks are by far the best bang for the buck.
Quick Reply: do front adjustable shocks/struts lower the car
